New interface
Conference papers
Realizing Unbiased Deformation: A Theoretical Consideration
Abstract : Maps of local tissue compression or expansion are often recovered by comparing MRI scans using nonlinear registration techniques. The resulting changes can be analyzed using tensor-based morphometry (TBM) to make inferences about anatomical differences. Numerous deformation techniques have been developed, although there has not been much theoretical development examining the mathematical/statistical validity of each technique. In this paper, we propose a basic principle that any registration technique should satisfy: realizing unbiased test statistics under null distribution of the displacement. In other words, any registration technique should recover zero change in the test statistic when comparing two images differing only in noise. Based on this principle, we propose a fundamental framework for the construction and analysis of image deformation. Moreover, we argue that logarithmic transform is instrumental in the analysis of deformation maps. Combined with the proposed framework, this leads to a theoretical connection between image registration and other branches of applied mathematics including information theory and grid generation.
Document type :
Conference papers
Complete list of metadata
Cited literature [29 references]  Display  Hide  Download
https://hal.inria.fr/inria-00636333
Contributor : Service Ist Inria Sophia Antipolis-Méditerranée / I3s Connect in order to contact the contributor
Submitted on : Thursday, October 27, 2011 - 12:00:10 PM
Last modification on : Tuesday, November 29, 2022 - 12:06:07 PM
File
Leow_MFCA06.pdf
Identifiers
  • HAL Id : inria-00636333, version 1
Collections
Citation
Alex Leow, Ming-Chang Chiang, S. C. Huang, Arthur W. Toga, Paul M. Thompson. Realizing Unbiased Deformation: A Theoretical Consideration. 1st MICCAI Workshop on Mathematical Foundations of Computational Anatomy: Geometrical, Statistical and Registration Methods for Modeling Biological Shape Variability, Oct 2006, Copenhagen, Denmark. pp.174-181. ⟨inria-00636333⟩
Share
Metrics
Record views
62
Files downloads
40
