The Squale Model - A Practice-based Industrial Quality Model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
ISO 9126 promotes a three-level model of quality (fac- tors, criteria, and metrics) which allows one to assess qual- ity at the top level of factors and criteria. However, it is dif- ficult to use this model as a tool to increase software quality. In the Squale model, we add practices as an intermediate level between metrics and criteria. Practices abstract away from raw information (metrics, tool reports, audits) and provide technical guidelines to respect. Moreover, practice marks are adjusted using formulae to suit company development habits or exigences: for example bad marks are stressed to point to places which need more attention. The Squale model has been developed and validated over the last couple of years in an industrial setting with Air France-KLM and PSA Peugeot-Citroën.
Mord09a-ICSM2009-SqualeModel.pdf (92.31 Ko) Télécharger le fichier
inria-00637364 , version 1 (01-11-2011)
  • HAL Id : inria-00637364 , version 1
Karine Mordal-Manet, Françoise Balmas, Simon Denier, Stéphane Ducasse, Harald Wertz, et al.. The Squale Model - A Practice-based Industrial Quality Model. International conference on Software maintenance, Nov 2009, Edmonton, Canada. ⟨inria-00637364⟩
280 Consultations
143 Téléchargements
