Invariant pattern recognition: A review, Pattern Recognition, vol.29, issue.1, pp.1-17, 1996. ,
DOI : 10.1016/0031-3203(95)00069-0
Review of shape representation and description techniques, Pattern Recognition, vol.37, issue.1, pp.1-19, 2004. ,
DOI : 10.1016/j.patcog.2003.07.008
Fourier Transforms, Transforms and Applications Handbook, 2010. ,
DOI : 10.1201/9781420066531-c2
Mellin transform, Transforms and Applications Handbook, p.12, 2010. ,
DOI : 10.1201/9781420066531-c12
Rotation-invariant digital pattern recognition using circular harmonic expansion, Applied Optics, vol.21, issue.22, pp.4012-4015, 1982. ,
DOI : 10.1364/AO.21.004012
Shape-based image retrieval using generic Fourier descriptor, Signal Processing: Image Communication, pp.825-848, 2002. ,
DOI : 10.1016/S0923-5965(02)00084-X
Image analysis via the general theory of moments*, Journal of the Optical Society of America, vol.70, issue.8, pp.920-930, 1980. ,
DOI : 10.1364/JOSA.70.000920
Fast Slant Stack: A Notion of Radon Transform for Data on A Cartesian Grid Which Is Rapidly Computable, Algebraically Exact, Geometrically Faithful, and Invertible, 2001. ,
Identification of Reflected, Scaled, Translated, and Rotated Objects From Their Radon Projections, IEEE Transactions on Image Processing, vol.17, issue.3, pp.301-310, 2008. ,
DOI : 10.1109/TIP.2007.916160
A new shape descriptor defined on the Radon transform, Computer Vision and Image Understanding, vol.102, issue.1, pp.42-51, 2004. ,
DOI : 10.1016/j.cviu.2005.06.005
URL : https://hal.archives-ouvertes.fr/inria-00000643
Shape-Based Image Retrieval Using a New Descriptor Based on the Radon and Wavelet Transforms, 2010 20th International Conference on Pattern Recognition, pp.1997-2000, 2010. ,
DOI : 10.1109/ICPR.2010.492
URL : https://hal.archives-ouvertes.fr/inria-00542493
Scaling and rotation invariant analysis approach to object recognition based on Radon and Fourier???Mellin transforms, Pattern Recognition, vol.40, issue.12, pp.3503-3508, 2007. ,
DOI : 10.1016/j.patcog.2007.04.020
A Geometric Invariant Shape Descriptor Based on the Radon, Fourier, and Mellin Transforms, 2010 20th International Conference on Pattern Recognition, pp.2085-2088, 2010. ,
DOI : 10.1109/ICPR.2010.512
URL : https://hal.archives-ouvertes.fr/inria-00512312
Invariant description and retrieval of planar shapes using Radon composite features, IEEE Transactions on Signal Processing, vol.56, issue.1, pp.10-11, 2008. ,
Use of the Hough transformation to detect lines and curves in pictures, Communications of the ACM, vol.15, issue.1, pp.11-15, 1972. ,
DOI : 10.1145/361237.361242
The Radon transform and its application to shape parametrization in machine vision, Image and Vision Computing, vol.5, issue.2, pp.161-166, 1987. ,
DOI : 10.1016/0262-8856(87)90044-8
Use of the Radon transform as a method of extracting information about shape in two dimensions, Image and Vision Computing, vol.10, issue.2, pp.99-107, 1992. ,
DOI : 10.1016/0262-8856(92)90004-M
The Trace transform and its applications, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.23, issue.8, pp.811-828, 2001. ,
DOI : 10.1109/34.946986
Appearance modeling using a geometric transform, IEEE Transactions on Image Processing, vol.18, issue.4 1, pp.889-902, 2009. ,
Optimal Classifier Fusion in a Non-Bayesian Probabilistic Framework, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.31, issue.9, pp.1630-1644, 2009. ,
DOI : 10.1109/TPAMI.2008.224
Viewpoint Manifolds for Action Recognition, EURASIP Journal on Image and Video Processing, vol.19, issue.4, pp.1-13, 2009. ,
DOI : 10.1109/34.387485
Human Activity Recognition Based on R Transform, 2007 IEEE Conference on Computer Vision and Pattern Recognition, 2007. ,
DOI : 10.1109/CVPR.2007.383505
Text extraction from graphical document images using sparse representation, Proceedings of the 8th IAPR International Workshop on Document Analysis Systems, DAS '10, pp.143-150, 2010. ,
DOI : 10.1145/1815330.1815349
URL : https://hal.archives-ouvertes.fr/inria-00494513
The Radon Transform and Some of Its Applications, 1993. ,
An efficient three-dimensional aircraft recognition algorithm using normalized fourier descriptors, Computer Graphics and Image Processing, vol.13, issue.2, pp.99-126, 1980. ,
DOI : 10.1016/S0146-664X(80)80035-9
Distance transformations in digital images, Computer Vision, Graphics, and Image Processing, vol.34, issue.3, pp.344-371, 1986. ,
DOI : 10.1016/S0734-189X(86)80047-0
A fast digital radon transform???an efficient means for evaluating the hough transform, Pattern Recognition, vol.29, issue.4, pp.711-718, 1996. ,
DOI : 10.1016/0031-3203(96)00015-5
A Fast Discrete Approximation Algorithm for the Radon Transform, SIAM Journal on Computing, vol.27, issue.1, pp.107-119, 1998. ,
DOI : 10.1137/S0097539793256673
Rotation-invariant multiresolution texture analysis using Radon and wavelet transforms, IEEE Transactions on Image Processing, vol.14, issue.6, pp.783-795, 2005. ,
DOI : 10.1109/TIP.2005.847302
Invariant pattern recognition using the RFM descriptor, Pattern Recognition, vol.45, issue.1, pp.271-284, 2012. ,
DOI : 10.1016/j.patcog.2011.06.020
URL : https://hal.archives-ouvertes.fr/inria-00614835
Columbia Object Image Library (COIL-20), 1996. ,
Applying algebraic and differential invariants for logo recognition, Machine Vision and Applications, pp.73-86, 1996. ,
DOI : 10.1007/BF01214362
Shape descriptors, " in Introduction to MPEG 7: Multimedia Content Description Language, pp.15-231, 2002. ,
Invariant image recognition by Zernike moments, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.12, issue.5, pp.489-497, 1990. ,
DOI : 10.1109/34.55109
On the generalised distance in statistics, Proceedings of the National Institute of Sciences of India, pp.49-55, 1936. ,
Modern Information Retrieval, 1999. ,
Learning context sensitive shape similarity by graph transduction, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.322, issue.5 62, pp.861-874, 2010. ,
