A generic framework: from modeling to code - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Innovations in Systems and Software Engineering (ISSE) Année : 2011
Model-driven development (MDD) is a very popular technique in the area of software development, but this technique is criticized due to lack of a formal semantics. MDD is used for large-scale system development using semi-formal techniques like UML (Unified Modeling Language), which are not amenable to formal analysis and consistency checking. Formal methods with MDD may provide an assurance of correctness of the system. This paper advocates an approach to building generic framework for rigorous MDD that is based on combining semi-formal notations with formal modeling languages, correctness of the system using model checker and automatic code generation from the verified formal specification. The main objective of this work is to apply model-driven techniques and tools with formal verification and its code generation for designing critical systems. An assessment of the proposed framework is given through a case study, relative to the development of a cardiac pacemaker system.
Fichier non déposé
inria-00637761 , version 1 (02-11-2011)
  • HAL Id : inria-00637761 , version 1
Dominique Méry, Neeraj Kumar Singh. A generic framework: from modeling to code. Innovations in Systems and Software Engineering (ISSE), 2011, pp.1-9. ⟨inria-00637761⟩
112 Consultations
0 Téléchargements
