A computational method for non-convex reachable sets using optimal control, Proceedings of the European Control Conference (ECC) 2009, pp.97-102, 2009. ,
Approximation of reachable sets using optimal control algorithms, Numerical Algebra, Control and Optimization, vol.3, issue.3, 2011. ,
DOI : 10.3934/naco.2013.3.519
URL : https://hal.archives-ouvertes.fr/inria-00637880
Sensitivity Analysis and Real-Time Control of Parametric Optimal Control Problems Using Nonlinear Programming Methods, Online Optimization of Large Scale Systems, pp.56-68, 2001. ,
DOI : 10.1007/978-3-662-04331-8_3
Introduction to Sensitivity and Stability Analysis in Nonlinear Programming, Mathematics in Science and Engineering, vol.165, 1983. ,
Solving mixed-integer optimal control problems by branch&bound: a case study from automobile test-driving with gear shift, Optimal Control Applications and Methods, vol.83, issue.1, pp.1-18, 2005. ,
DOI : 10.1002/oca.751
A variable time transformation method for mixed-integer optimal control problems, Optimal Control Applications and Methods, vol.83, issue.3, pp.169-182, 2006. ,
DOI : 10.1002/oca.778
Generating locally optimal trajectories for??an??automatically driven car, Optimization and Engineering, vol.2, issue.4, pp.439-463, 2009. ,
DOI : 10.1007/s11081-008-9047-1
OCPID-DAE1 ? Optimal Control and Parameter Identification with Differential-Algebraic Equations of Index 1: User's Guide, 2011. ,
Unfallentwicklung auf deutschen Strassen, Statistisches Bundesamt, 2008. ,
