Distributed Busacker-Gowen algorithm for end-to-end QoS pipe negotiation in X-domain networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Annals of Telecommunications - annales des télécommunications Année : 2008
Multimedia services and other critical multisite services (e.g., VPN) are becoming mainstream, and they require a guaranteed quality of service (QoS). Services need to be established across several autonomous systems (ASes), often to connect end-users. Thus, provisioning and control of end-to-end QoS requirements arise as one of the main challenges in inter-AS management. The contractual approach, consisting in using service-level agreements (SLAs) defined by each crossed AS, allows to negotiate contract chains that satisfy end-to-end requirements. However, establishing such chains by on-demand negotiations does not scale up for large numbers of requests. Hence, we propose a negotiation process to occur before users' requests to establish service are received. The proposed negotiation process results in the selection of aggregated contract chains, called pipes, and a distribution between them. Such a distribution would indicate, for each chain of a pipe, the connection flow it may accept. In this paper, we address the pipe negotiation problem as a network flow problem. We also propose a distributed adaptation of an algorithm for network flow problems.
Autre [cs.OH]
inria-00638272 , version 1 (04-11-2011)
Hélia Pouyllau, Stefan Haar. Distributed Busacker-Gowen algorithm for end-to-end QoS pipe negotiation in X-domain networks. Annals of Telecommunications - annales des télécommunications, 2008, 63 (11-12), pp.621-630. ⟨10.1007/s12243-008-0055-0⟩. ⟨inria-00638272⟩
431 Consultations
0 Téléchargements
