Conference papers
Testing Systems Specified as Partial Order Input\slashOutput Automata
Abstract : An Input/Output Automaton is an automaton with a finite number of states where each transition is associated with a single inpuf or output interaction. In [1], we introduced a new formalism, in which each transition is associated with a bipartite partially ordered set made of concurrent inputs followed by concurrent outputs. In this paper, we generalize this model to Partial Order Input/Output Automata (POIOA), in which each transition is associated with an almost arbitrary partially ordered set of inputs and outputs. This formalism can be seen as High-Level Messages Sequence Charts with inputs and outputs and allows for the specification of concurrency between inputs and outputs in a very general, direct and concise way. We give a formal definition of this framework, and define several conformance relations for comparing system specifications expressed in this formalism. Then we show how to derive a test suite that guarantees to detect faults defined by a POIOA-specific fault model: missing output faults, unspecified output faults, weaker precondition faults, stronger precondition faults and transfer faults.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/inria-00638305
Contributor : Stefan Haar Connect in order to contact the contributor
Submitted on : Friday, November 4, 2011 - 3:05:31 PM
Last modification on : Friday, February 4, 2022 - 3:18:23 AM
Links full text
Identifiers
Citation
Gregor von Bochmann, Stefan Haar, Claude Jard, Guy-Vincent Jourdan. Testing Systems Specified as Partial Order Input\slashOutput Automata. Proceedings of the 20th IFIP TC 6/WG 6.1 International Conference on Testing of Software and Communicating Systems (TestCom'08) and 8th International Workshop on Formal Approaches to Testing of Software (FATES'08), 2008, Tokyo, Japan, Japan. pp.169-183, ⟨10.1007/978-3-540-68524-1_13⟩. ⟨inria-00638305⟩
Share
Metrics
Record views
162
