Cambiera: Collaborative Tabletop Visual Analytics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Danyel Fisher
  • Fonction : Auteur
  • PersonId : 899585
Cambiera is a tabletop system designed for co-located collaborative visual analytics. As a tabletop system, Cambiera encourages analysts to face each other around the tabletop to analyze large text document collections collaboratively. Cambiera allows analysts to search for documents and read them, organize documents on the tabletop, and to monitor each other's' work. The video illustrates the major collaborative features of Cambiera.
Isenberg_2011_CVA.pdf (258.17 Ko) Télécharger le fichier
Cambiera.wmv (24.83 Mo) Télécharger le fichier
Format : Vidéo
inria-00638536 , version 1 (05-11-2011)
inria-00638536 , version 2 (07-08-2012)
Petra Isenberg, Danyel Fisher. Cambiera: Collaborative Tabletop Visual Analytics. Videos of the ACM Conference on Computer Supported Cooperative Work (CSCW), Mar 2011, New York, NY, United States. ⟨10.1145/1958824.1958916⟩. ⟨inria-00638536v1⟩
111 Consultations
293 Téléchargements
