Obvious: A Meta-Toolkit to Encapsulate Information Visualization Toolkits --- One Toolkit to Bind Them All - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pierre-Luc Hémery
  • Fonction : Auteur
  • PersonId : 913396
Thomas Baudel
Jo Wood
  • Fonction : Auteur
  • PersonId : 913397
This article describes "Obvious": a meta-toolkit that abstracts and encapsulates information visualization toolkits implemented in the Java language. It intends to unify their use and postpone the choice of which concrete toolkit(s) to use later-on in the development of visual analytics applications. We also report on the lessons we have learned when wrapping popular toolkits with Obvious, namely Prefuse, the InfoVis Toolkit, partly Improvise, JUNG and other data management libraries. We show several examples on the uses of Obvious, how the different toolkits can be combined, for instance sharing their data models. We also show how Weka and Rapid-Miner, two popular machine-learning toolkits, have been wrapped with Obvious and can be used directly with all the other wrapped toolkits. We expect Obvious to start a co-evolution process: Obvious is meant to evolve when more components of Information Visualization systems will become consensual. It is also designed to help information visualization systems adhere to the best practices to provide a higher level of interoperability and leverage the domain of visual analytics.
obvious.pdf (438.79 Ko) Télécharger le fichier
inria-00638578 , version 1 (06-11-2011)
  • HAL Id : inria-00638578 , version 1
Jean-Daniel Fekete, Pierre-Luc Hémery, Thomas Baudel, Jo Wood. Obvious: A Meta-Toolkit to Encapsulate Information Visualization Toolkits --- One Toolkit to Bind Them All. Visual Analytics Science and Technology (VAST), 2011 IEEE Symposium on, IEEE, Oct 2011, Providence, RI, United States. pp.89--98. ⟨inria-00638578⟩
222 Consultations
306 Téléchargements
