BioMart Central Portal: an open database network for the biological community - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Database - The journal of Biological Databases and Curation Année : 2011
Jeremy Mason
Linda Sperling
  • Fonction : Auteur
  • PersonId : 908715
J. Teague
  • Fonction : Auteur
Jun Wang
  • Fonction : Auteur
  • PersonId : 881572
BioMart Central Portal is a first of its kind, community-driven effort to provide unified access to dozens of biological databases spanning genomics, proteomics, model organisms, cancer data, ontology information and more. Anybody can contribute an independently maintained resource to the Central Portal, allowing it to be exposed to and shared with the research community, and linking it with the other resources in the portal. Users can take advantage of the common interface to quickly utilize different sources without learning a new system for each. The system also simplifies cross-database searches that might otherwise require several complicated steps. Several integrated tools streamline common tasks, such as converting between ID formats and retrieving sequences. The combination of a wide variety of databases, an easy-to-use interface, robust programmatic access and the array of tools make Central Portal a one-stop shop for biological data querying. Here, we describe the structure of Central Portal and show example queries to demonstrate its capabilities. Database URL: http://central.biomart.org.
BioMart_Central_Portal-accepted.pdf (649.08 Ko) Télécharger le fichier
inria-00638749 , version 1 (28-10-2013)
Paternité - Pas d'utilisation commerciale
Jonathan M. Guberman, J. Ai, O. Arnaiz, Baran Joachim, Andrew Blake, et al.. BioMart Central Portal: an open database network for the biological community. Database - The journal of Biological Databases and Curation, 2011, pp.bar041. ⟨10.1093/database/bar041⟩. ⟨inria-00638749⟩
1731 Consultations
908 Téléchargements
