Program optimization carving for GPU computing, Journal of Parallel and Distributed Computing, vol.68, issue.10, pp.1389-1401, 2008. ,
DOI : 10.1016/j.jpdc.2008.05.011
A performance study of general-purpose applications on graphics processors using CUDA, Journal of Parallel and Distributed Computing, vol.68, issue.10, pp.1370-1380, 2008. ,
DOI : 10.1016/j.jpdc.2008.05.014
Scalable parallel programming with CUDA, Queue, vol.6, issue.2, pp.40-53, 2008. ,
DOI : 10.1145/1365490.1365500
Parallel Implementation of the 2D Discrete Wavelet Transform on Graphics Processing Units: Filter Bank versus Lifting, IEEE Transactions on Parallel and Distributed Systems, vol.19, issue.3, pp.299-310, 2008. ,
DOI : 10.1109/TPDS.2007.70716
An efficient finegrained parallel genetic algorithm based on gpu-accelerated, Network and Parallel Computing Workshops NPC Workshops. IFIP International Conference, pp.855-862, 2007. ,
A data parallel approach to genetic programming using programmable graphics hardware, Proceedings of the 9th annual conference on Genetic and evolutionary computation , GECCO '07, pp.1566-1573, 2007. ,
DOI : 10.1145/1276958.1277274
Parallel evolutionary algorithms on consumer-level graphics processing unit Robust taboo search for the quadratic assignment problem, Parallel Evolutionary Computations, pp.133-155, 1991. ,
Ant colony system: a cooperative learning approach to the traveling salesman problem, IEEE Transactions on Evolutionary Computation, vol.1, issue.1, pp.53-66, 1997. ,
DOI : 10.1109/4235.585892
Holder functions and deception of genetic algorithms, IEEE Transactions on Evolutionary Computation, vol.2, issue.2, pp.56-71, 1998. ,
DOI : 10.1109/4235.728208
URL : https://hal.archives-ouvertes.fr/inria-00592413
Metaheuristics: From design to implementation, 2009. ,
DOI : 10.1002/9780470496916
URL : https://hal.archives-ouvertes.fr/hal-00750681
Massively parallel tabu search for the quadratic assignment problem, Annals of Operations Research, vol.17, issue.4, pp.327-341, 1993. ,
DOI : 10.1007/BF02022999
Parallel asynchronous tabu search for multicommodity location-allocation with balancing requirements, Annals of Operations Research, vol.6, issue.2, pp.277-299, 1995. ,
DOI : 10.1007/BF02125458
A parallel implementation of the Tabu search heuristic for vehicle routing problems with time window constraints, Computers & Operations Research, vol.21, issue.9, pp.1025-1033, 1994. ,
DOI : 10.1016/0305-0548(94)90073-6
A comparison of eleven static heuristics for mapping a class of independent tasks onto heterogeneous distributed computing systems, J. Parallel Distrib. Comput, vol.61, issue.6, pp.810-837, 2001. ,
A cooperative parallel tabu search algorithm for the quadratic assignment problem, European Journal of Operational Research, vol.195, issue.3, pp.810-826, 2009. ,
DOI : 10.1016/j.ejor.2007.06.061
A Methodological Approach to Parallel Simulated Annealing on an SMP System, Journal of Parallel and Distributed Computing, vol.62, issue.10, pp.1548-1570, 2002. ,
DOI : 10.1016/S0743-7315(02)91863-0
A Comparative Study of Parallel Metaheuristics for Protein Structure Prediction on the Computational Grid, 2007 IEEE International Parallel and Distributed Processing Symposium, pp.1-10, 2007. ,
DOI : 10.1109/IPDPS.2007.370439
URL : https://hal.archives-ouvertes.fr/hal-00683904
The GPU Computing Era, IEEE Micro, vol.30, issue.2, pp.56-69, 2010. ,
DOI : 10.1109/MM.2010.41
Model-driven autotuning of sparse matrix-vector multiply on GPUs, ACM SIGPLAN Notices, vol.45, issue.5, pp.115-126, 2010. ,
DOI : 10.1145/1837853.1693471
Auto-tuning 3-d fft library for cuda gpus Storage and Analysis, ser. SC '09, Proceedings of the Conference on High Performance Computing Networking, pp.301-3010, 2009. ,
Tabu Search applied to global optimization, European Journal of Operational Research, vol.123, issue.2, pp.256-270, 2000. ,
DOI : 10.1016/S0377-2217(99)00255-6
Comparing the openmp, mpi, and hybrid programming paradigm on an smp cluster, 2003. ,
Grid computing for parallel bioinspired algorithms, Journal of Parallel and Distributed Computing, vol.66, issue.8, pp.1052-1061, 2006. ,
DOI : 10.1016/j.jpdc.2005.11.006
URL : https://hal.archives-ouvertes.fr/hal-00684951
OpenCL 1.1 Quick Reference Card, 2011. ,
ParadisEO: A Framework for the Reusable Design of Parallel and Distributed Metaheuristics, Journal of Heuristics, vol.10, issue.3, pp.357-380, 2004. ,
DOI : 10.1023/B:HEUR.0000026900.92269.ec
