Copy-neutral loss of heterozygosity and chromosome gains and losses are frequent in gastrointestinal stromal tumors. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Molecular Cancer Année : 2014
Emmanuel Martin
A KIT gain of function mutation is present in 70% of gastrointestinal stromal tumors (GISTs) and the wild-type (WT) allele is deleted in 5 to 15% of these cases. The WT KIT is probably deleted during GIST progression. We aimed to identify the mechanism of WT KIT loss and to determine whether other genes are involved or affected. Whole-genome SNP array analyses were performed in 22 GISTs with KIT exon 11 mutations, including 11 with WT loss, to investigate the mechanisms of WT allele deletion. CGH arrays and FISH were performed in some cases. Common genetic events were identified by SNP data analysis. The 9p21.3 locus was studied by multiplex quantification of genomic DNA. Chromosome instability involving the whole chromosome/chromosome arm (whole C/CA) was detected in 21/22 cases. The GISTs segregated in two groups based on their chromosome number: polyGISTs had numerous whole C/CA gains (mean 23, range [9 to 43]/3.11 [1 to 5]), whereas biGISTs had fewer aberrations. Whole C/CA losses were also frequent and found in both groups. There were numerous copy-neutral losses of heterozygosity (cnLOH) of whole C/CA in both polyGIST (7/9) and biGIST (9/13) groups. cnLOH were frequent on 4q, 11p, 11q, 1p, 2q, 3p and 10, and never involved 12p, 12q, 20p, 20q or 19q. Other genetic alterations included segmental chromosome abnormalities, complete bi-allelic deletions (homozygous deletions) and, more rarely, amplifications. Nine of 11 GISTs with homozygous KIT exon 11 mutations had cnLOH of chromosome 4. The cnLOH of whole C/CA is a frequent genetic alteration in GISTs and is closely associated with homozygous mutations of KIT and WT allele deletion.
Mots clés
Cancer Génétique
1476-4598-13-246.pdf (1.77 Mo) Télécharger le fichier
inserm-01188061 , version 1 (28-08-2015)
Nelson Lourenço, Zofia Hélias-Rodzewicz, Jean-Baptiste Bachet, Sabrina Brahimi-Adouane, Fabrice Jardin, et al.. Copy-neutral loss of heterozygosity and chromosome gains and losses are frequent in gastrointestinal stromal tumors.. Molecular Cancer, 2014, 13 (1), pp.246. ⟨10.1111/j.1365-2141.2009.07791.x⟩. ⟨inserm-01188061⟩
208 Consultations
287 Téléchargements
