Osteoprotegerin and tumor necrosis factor-related apoptosis-inducing ligand as prognostic factors in rheumatoid arthritis: results from the ESPOIR cohort. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Arthritis Research and Therapy Année : 2015
We previously reported that low ratio of osteoprotegerin (OPG) to tumor necrosis factor-related apoptosis-inducing ligand (TRAIL) was associated with Disease Activity Score in 28 joints (DAS28) remission at 6 months in patients with early rheumatoid arthritis (RA). Here, we aimed to evaluate the value of baseline OPG/TRAIL ratio in predicting clinical and radiological outcomes in patients with early RA in the ESPOIR cohort. OPG and TRAIL serum concentrations were assessed in the ESPOIR cohort patients. Patients with definite RA were included in this study. Patients were excluded if they had high erosion score at baseline (>90(th) percentile) or received biological therapy during the first 2 years of follow-up. Data were analyzed by univariate analysis and multivariate logistic regression to predict 1-year DAS28 remission and 2-year radiographic disease progression. On univariate analysis of 399 patients, OPG/TRAIL ratio at baseline was significantly lower in patients with than without remission at 1 year (p = 0.015). On multivariate logistic regression including age, gender, body mass index and DAS28, low OPG/TRAIL ratio was independently associated with remission at 1 year (odds ratio 1.68 [95 % confidence interval 1.01-2.79]). On univariate analysis, high OPG/TRAIL ratio at baseline was associated with rapid progression of erosion at 2 years (p = 0.041), and on multivariate logistic regression including age, anti-citrullinated protein antibody positivity and C-reactive protein level, OPG/TRAIL ratio independently predicted rapid progression of erosion at 2 years. OPG/TRAIL ratio at baseline was an independent predictor of 1-year remission and 2-year rapid progression of erosion for patients with early rheumatoid arthritis. Thus, OPG/TRAIL ratio could be included in matrix prediction scores to predict rapid radiographic progression. Further confirmation in an independent cohort is warranted.
Immunologie
s13075-015-0705-3.pdf (535.65 Ko) Télécharger le fichier
inserm-01188176 , version 1 (28-08-2015)
Rachel Audo, Claire Daien, Laura Papon, Cédric Lukas, Olivier Vittecoq, et al.. Osteoprotegerin and tumor necrosis factor-related apoptosis-inducing ligand as prognostic factors in rheumatoid arthritis: results from the ESPOIR cohort.. Arthritis Research and Therapy, 2015, 17, pp.193. ⟨10.1186/s13075-015-0705-3⟩. ⟨inserm-01188176⟩
202 Consultations
143 Téléchargements
