The heptad repeat domain 1 of Mitofusin has membrane destabilization function in mitochondrial fusion
Abstract : Mitochondria are double-membrane-bound organelles that constantly change shape through membrane fusion and fission. Outer mitochondrial membrane fusion is controlled by Mitofusin, whose molecular architecture consists of an N-terminal GTPase domain, a first heptad repeat domain (HR1), two transmembrane domains, and a second heptad repeat domain (HR2). The mode of action of Mitofusin and the specific roles played by each of these functional domains in mitochondrial fusion are not fully understood. Here, using a combination of in situ and in vitro fusion assays, we show that HR1 induces membrane fusion and possesses a conserved amphipathic helix that folds upon interaction with the lipid bilayer surface. Our results strongly suggest that HR1 facilitates membrane fusion by destabilizing the lipid bilayer structure, notably in membrane regions presenting lipid packing defects. This mechanism for fusion is thus distinct from that described for the heptad repeat domains of SNARE and viral proteins, which assemble as membrane-bridging complexes, triggering close membrane apposition and fusion, and is more closely related to that of the C-terminal amphipathic tail of the Atlastin protein.
Document type :
Journal articles
Complete list of metadatas
Cited literature [73 references]  Display  Hide  Download
https://www.hal.inserm.fr/inserm-02293215
Contributor : Clara Martinez Rico <>
Submitted on : Friday, September 20, 2019 - 4:27:22 PM
Last modification on : Sunday, September 22, 2019 - 1:08:51 AM
File
EMBR-19-e43637.pdf
Identifiers
Citation
Frédéric Daste, Cécile Sauvanet, Andrej Bavdek, James Baye, Fabienne Pierre, et al.. The heptad repeat domain 1 of Mitofusin has membrane destabilization function in mitochondrial fusion. EMBO Reports, EMBO Press, 2018, 19 (6), ⟨10.15252/embr.201643637⟩. ⟨inserm-02293215⟩
Share
Metrics
Record views
69
Files downloads
31
