Molecular Classification of Malignant Pleural Mesothelioma: Identification of a Poor Prognosis Subgroup Linked to the Epithelial-to-Mesenchymal Transition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Clinical Cancer Research Année : 2014
Didier Jean
PURPOSE: Despite research efforts to develop more effective diagnostic and therapeutic approaches, malignant pleural mesothelioma (MPM) prognosis remains poor. The assessment of tumor response to therapy can be improved by a deeper phenotypical classification of the tumor, with emphasis on its clinico-biological heterogeneity. The identification of molecular profiles is a powerful approach to better define MPM subclasses and targeted therapies. EXPERIMENTAL DESIGN: Molecular subclasses were defined by transcriptomic microarray on 38 primary MPM cultures. A three-gene predictor, identified by quantitative reverse transcription PCR, was used to classify an independent series of 108 frozen tumor samples. Gene mutations were determined in BAP1, CDKN2A, CDKN2B, NF2, and TP53. Epithelial-to-mesenchymal transition (EMT) markers were studied at the mRNA and protein levels. RESULTS: Unsupervised hierarchical clustering on transcriptomic data defined two robust MPM subgroups (C1 and C2), closely related to prognosis and partly to histologic subtypes. All sarcomatoid/desmoplastic MPM were included in the C2 subgroup. Epithelioid MPM were found in both subgroups, with a worse survival prognosis in the C2 subgroup. This classification and its association with histologic subtypes and survival were validated in our independent series using the three-gene predictor. Similar subgroups were found after classification of other MPM series from transcriptomic public datasets. C1 subgroup exhibited more frequent BAP1 alterations. Pathway analysis revealed that EMT was differentially regulated between MPM subgroups. C2 subgroup is characterized by a mesenchymal phenotype. CONCLUSIONS: A robust classification of MPM that defines two subgroups of epithelioid MPM, characterized by different molecular profiles, gene alterations, and survival outcomes, was established.
Fichier sous embargo
Date de visibilité indéterminée
inserm-02478599 , version 1 (14-02-2020)
inserm-02478599 , version 2 (14-02-2020)
Aurélien de Reyniès, Marie-Claude Jaurand, Annie Renier, Gabrielle Couchy, Ilir Hysi, et al.. Molecular Classification of Malignant Pleural Mesothelioma: Identification of a Poor Prognosis Subgroup Linked to the Epithelial-to-Mesenchymal Transition. Clinical Cancer Research, 2014, 20 (5), pp.1323-1334. ⟨10.1158/1078-0432.CCR-13-2429⟩. ⟨inserm-02478599v1⟩
172 Consultations
172 Téléchargements
