Isolating the Sources of Pipeline-Variability in Group-Level Task-fMRI results - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Human Brain Mapping Année : 2022
While the development of tools and techniques has broadened our horizons for comprehending the complexities of the human brain, a growing body of research has highlighted the pitfalls of such methodological plurality. In a recent study, we found that the choice of software package used to run the analysis pipeline can have a considerable impact on the final group-level results of a task-fMRI investigation (Bowring et al., 2019, BMN ). Here we revisit our work, seeking to identify the stages of the pipeline where the greatest variation between analysis software is induced. We carry out further analyses on the three datasets evaluated in BMN , employing a common processing strategy across parts of the analysis workflow and then utilizing procedures from three software packages (AFNI, FSL and SPM) across the remaining steps of the pipeline. We use quantitative methods to compare the statistical maps and isolate the main stages of the workflow where the three packages diverge. Across all datasets, we find that variation between the packages’ results is largely attributable to a handful of individual analysis stages, and that these sources of variability were heterogeneous across the datasets (e.g. choice of first-level signal model had the most impact for the ds000001 dataset, while first-level noise model was more influential for ds000109 dataset). We also observe areas of the analysis workflow where changing the software package causes minimal differences in the final results, finding that the group-level results were largely unaffected by which software package is used to model the low-frequency fMRI drifts.
Neurosciences
2021.07.27.453994v1.full.pdf (2.01 Mo) Télécharger le fichier
Origine : Publication financée par une institution
inserm-03323001 , version 1 (20-08-2021)
Alexander Bowring, Thomas Nichols, Camille Maumet. Isolating the Sources of Pipeline-Variability in Group-Level Task-fMRI results. Human Brain Mapping, 2022, 43 (3), pp.1112-1128. ⟨10.1002/hbm.25713⟩. ⟨inserm-03323001⟩
142 Consultations
244 Téléchargements
