Eddy properties in the Western Mediterranean Sea from satellite altimetry and a numerical simulation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Geophysical Research. Oceans Année : 2016
Three different eddy detection and tracking methods are applied to the outputs of a high-resolution simulation in the Western Mediterranean Sea in order to extract mesoscale eddy characteristics. The results are compared with the same eddy statistics derived from satellite altimetry maps over the same period. Eddy radii are around 30 km in altimetry maps whereas, in the model, they are around 20 km. This is probably due to the inability of altimetry maps to resolve the smaller mesoscale in the region. About 30 eddies are detected per day in the basin with a very heterogeneous spatial distribution and relatively short lifespans (median life around 13 days). Unlike other areas of the open ocean, they do not have a preferred direction of propagation but appear to be advected by mean currents. The number of detected eddies seems to present an annual cycle when separated according to their lifespan. With the numerical simulation, we show that anticyclones extend deeper in the water column and have a more conic shape than cyclones.
2015JC011371.pdf (20.01 Mo) Télécharger le fichier
insu-01389526 , version 1 (04-03-2021)
Romain Escudier, Lionel Renault, Ananda Pascual, Pierre Brasseur, Dudley Chelton. Eddy properties in the Western Mediterranean Sea from satellite altimetry and a numerical simulation. Journal of Geophysical Research. Oceans, 2016, 121 (6), pp.3990-4006. ⟨10.1002/2015JC011371⟩. ⟨insu-01389526⟩
151 Consultations
22 Téléchargements
