La structure de la chaîne hercynienne de la meseta ibérique : Histoire structurale du Golfe de Gascogne (Tome 1) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ouvrage (Y Compris Édition Critique Et Traduction) Année : 1971
The major features concerning stratigraphy, tectonics, metamorphism and granitic magmatism of the iberian va- riscan (hercynian) belt are exposed in order to compare the neighbouring european segments, particulary those situated at the northern part of the Biscay Bay. Striking similarities exist between the north-western part of the iberian Peninsula (Galicia) and the french massif Armoricain, namely when regarding the repartition and the petrological caracters of the metamorphic belts and the various hercynian granites. This suggests that the Galicia and the massif Armoricain belonged to the same contiguous orogen and that the south armorican and north iberian continental shelves were fitting at least at the end of the Hercynian. The authors discuss briefly the openning process of the Biscay Bay; they propose it is neither a simple rotation nor a translation, but the combination of these two mechanisms (first : sinistrial translation along a curviplanar transcurrent and/or transform fault; then, low-angle anticlockwise rotations during the Mesozoic and the Cenozoic). At the continental drift-scale, the consequences of these hypothesis are envisaged regarding the outline of the variscan belt in Europe and North Africa and its relations with the rest of the intrapaleozoic peri-Atlantic belts. For the authors, the Caledonian/ Appalachian orogens and the Hercynian are two independent systems but possibly related in space and time in the area between the western Africa and the south-eastern part of North America*
On expose brièvement les grands traits de la stratigraphie» de la tectonique, du métamorphisme et du magmatisme granitique de la chaîne hercynienne ibérique» afin de tenter des corrélations avec les segments voisins» particulièrement ceux situés au nord du golfe de Gascogne. Des similitudes frappantes existent entre lfextrémité nord- ouest de la chaîne hercynienne ibérique (Galice) et l'ensemble massif Armoricain-Massif central français; notamment la répartition et la nature des bandes métamorphiques et des granites hercyniens suggèrent que la -partie méridionale du massif Armoricain est la continuation de la zone axiale de Galice. On est ainsi amené à penser que la bordure continentale nord-ibérique et le plateau continental armoricain étaient jointifs à la fin de l'orogenèse hercynienne. On discute alors le mécanisme d'ouverture du golfe de Gascogne responsable de la configuration actuelle. Il ne peut s'agir d'une simple rotation à partir du Mésozoïque autour d'un axe situé à la pointe du golfe, incompatible avec la structure de la chaîne pyrénéenne. Cependant la combinaison d'une translation tardi-hercynienne de la péninsule vers l'est, le long d'un décrochement courbe et d’une rptation partielle, au Mésozoïque est susceptible d’expliquer l’allure actuelle du golfe de Gascogne. Les conséquences de cette hypothèse sur le tracé de la chaîne hercynienne en Europe méridionale et en Afrique, et ses relations avec la chaîne calêdono-appalachien- ne sont envisagées.
MA0072-Bard.pdf (7.16 Mo) Télécharger le fichier
insu-01493984 , version 1 (28-03-2017)
  • HAL Id : insu-01493984 , version 1
J.-P Bard, R Capdevila. La structure de la chaîne hercynienne de la meseta ibérique : Histoire structurale du Golfe de Gascogne (Tome 1) . 22, pp.I.4.1-I.4.68, 1971. ⟨insu-01493984⟩
Collections
INSU GR-MA
102 Consultations
1078 Téléchargements
