Ionospheric response to the 2015 St. Patrick's Day storm: A global multi-instrumental overview - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Geophysical Research Space Physics Année : 2015
We present the first multi-instrumental results on the ionospheric response to the geomagnetic storm of 17–18 March 2015 (the St. Patrick's Day storm) that was up to now the strongest in the 24th solar cycle (minimum SYM-H value of À233 nT). The storm caused complex effects around the globe. The most dramatic positive ionospheric storm occurred at low latitudes in the morning (~100–150% enhancement) and postsunset (~80–100% enhancement) sectors. These significant vertical total electron content increases were observed in different local time sectors and at different universal time, but around the same area of the Eastern Pacific region, which indicates a regional impact of storm drivers. Our analysis revealed that this particular region was most concerned by the increase in the thermospheric O/N 2 ratio. At midlatitudes, we observe inverse hemispheric asymmetries that occurred, despite the equinoctial period, in different longitudinal regions. In the European-African sector, positive storm signatures were observed in the Northern Hemisphere (NH), whereas in the American sector, a large positive storm occurred in the Southern Hemisphere, while the NH experienced a negative storm. The observed asymmetries can be partly explained by the thermospheric composition changes and partly by the hemispherically different nondipolar portions of the geomagnetic field as well as by the IMF By component variations. At high latitudes, negative ionospheric storm effects were recorded in all longitudinal regions, especially the NH of the Asian sector was concerned. The negative storm phase developed globally on 18 March at the beginning of the recovery phase.
Astafyeva_et_al-2015-Journal_of_Geophysical_Research__Space_Physics-120-9023.pdf (2.83 Mo) Télécharger le fichier
insu-01514406 , version 1 (26-04-2017)
Elvira Astafyeva, Irina Zakharenkova, Matthias Förster. Ionospheric response to the 2015 St. Patrick's Day storm: A global multi-instrumental overview. Journal of Geophysical Research Space Physics, 2015, 120 (10), pp.9023-9037. ⟨10.1002/2015JA021629⟩. ⟨insu-01514406⟩
136 Consultations
413 Téléchargements
