Multiple Scattering Effects in the Interplanetary Medium: Evaluation Using SOHO SWAN and MAVEN EUVM Lyman α Measurements - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Geophysical Research Space Physics Année : 2019
Interplanetary background measurements can be used to derive the solar flux that is illuminating the atoms in the interplanetary medium. We present a new algorithm combining measurements from the SWAN‐SOHO Lyman α photometer with Earth‐based solar flux measurements to derive the solar illuminating flux at Lyman α in any direction along the ecliptic plane. The modulations of the solar flux and the interplanetary background intensity are proportional. The proportionality coefficient is a direct measurement of the fraction of the interplanetary brightness that is due to single scattering in the interplanetary medium. We find that for an observer at 1 AU from the Sun, single scattering photons represent roughly 70% of the total brightness. This new algorithm is tested by a comparison with actual measurements from the EUVM‐MAVEN solar monitor in orbit around Mars since 2014.
Qu-merais_et_al-2019-Journal_of_Geophysical_Research__Space_Physics.pdf (1.12 Mo) Télécharger le fichier
Origine : Publication financée par une institution
insu-02151127 , version 1 (11-09-2019)
Eric Quémerais, Edward Thiemann, Martin Snow, Stéphane Ferron, Walter Schmidt. Multiple Scattering Effects in the Interplanetary Medium: Evaluation Using SOHO SWAN and MAVEN EUVM Lyman α Measurements. Journal of Geophysical Research Space Physics, 2019, 124 (6), pp.3949-3960. ⟨10.1029/2019JA026674⟩. ⟨insu-02151127⟩
89 Consultations
154 Téléchargements
