A weather regime characterisation of winter biomass aerosol transport from southern Africa - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Atmospheric Chemistry and Physics Discussions Année : 2021
During austral winter, a compact low cloud deck over South Atlantic contrasts with clear sky over southern Africa, where forest fires triggered by dry conditions emit large amount of biomass burning aerosols (BBA) in the free troposphere. Most of the BBA burden crosses South Atlantic embedded in the tropical easterly flow. However, midlatitude synoptic disturbances can deflect part of the aerosol from the main transport path towards southern extratropics. In this study, a characterisation of the synoptic variability controlling the spatial distribution of BBA in southern Africa and South Atlantic during austral winter (August to October) is presented. By analysing atmospheric circulation data from reanalysis products, a 6-class weather regime (WR) classification of the region is constructed. The classification reveals that the synoptic variability is composed by four WRs representing disturbances travelling at midlatitudes, and two WRs accounting for pressure anomalies in the South Atlantic. The WR classification is then successfully used to characterise the aerosol spatial distribution in the region in the period 2003-2017, in both reanalysis products and station data. Results show that the BBA transport towards southern extratropics is controlled by weather regimes associated with midlatitude synoptic disturbances. In particular, depending on the relative position of the pressure anomalies along the midlatitude westerly flow, the BBA transport is deflected from the main tropical route towards southern Africa or the South Atlantic. This paper presents the first objective classification of the winter synoptic circulation over South Atlantic and southern Africa. The classification shows skills in characterising the BBA transport, indicating the potential for using it as a diagnostic/predictive tool for aerosol dynamics, which is a key component for the full understanding and modelling of the complex radiation-aerosol-cloud interactions controlling the atmospheric radiative budget in the region.
acp-2021-337.pdf (2.92 Mo) Télécharger le fichier
insu-03203447 , version 1 (20-04-2021)
insu-03203447 , version 2 (12-11-2021)
Paternité - Pas d'utilisation commerciale
Marco Gaetani, Benjamin Pohl, Maria del Carmen Alvarez Castro, Cyrille Flamant, Paola Formenti. A weather regime characterisation of winter biomass aerosol transport from southern Africa. Atmospheric Chemistry and Physics Discussions, 2021, pp.(Under Review). ⟨10.5194/acp-2021-337⟩. ⟨insu-03203447v1⟩
397 Consultations
85 Téléchargements
