Re‐analysis of the Cassini RPWS/LP data in Titan’s ionosphere. Part I: detection of several electron populations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Geophysical Research Space Physics Année : 2021
Current models of Titan's ionosphere have difficulties in explaining the observed electron density and/or temperature. In order to get new insights, we re-analyzed the data taken in the ionosphere of Titan by the Cassini Langmuir probe (LP), part of the Radio and Plasma Wave Science (RPWS) instrument. This is the first of two papers that present the new analysis method (current paper) and statistics on the whole dataset. We suggest that between 2 and 4 electron populations are necessary to fit the data. Each population is defined by a potential, an electron density and an electron temperature and is easily visualized by a dinstinct peak in the second derivative of the electron current, which is physically related to the electron energy distribution function (Druyvesteyn method). The detected populations vary with solar illumination and altitude. We suggest that the 4 electron populations are due to photo-ionization, magnetospheric particles, dusty plasma and electron emission from the probe boom, respectively.
essoar.10503740.1.pdf (1.68 Mo) Télécharger le fichier
insu-03298835 , version 1 (26-07-2021)
Audrey Chatain, J.-E. Wahlund, O. Shebanits, L. Z. Hadid, M. Morooka, et al.. Re‐analysis of the Cassini RPWS/LP data in Titan’s ionosphere. Part I: detection of several electron populations. Journal of Geophysical Research Space Physics, 2021, 126 (8), pp.e2020JA028412. ⟨10.1029/2020JA028412⟩. ⟨insu-03298835⟩
153 Consultations
58 Téléchargements
