Solar minimum exospheric neutral density near the subsolar magnetopause estimated from the XMM soft X‐ray observations on 12 November 2008 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Geophysical Research Space Physics Année : 2022
The Earth’s magnetosheath and cusps emit soft X-rays due to the charge exchange between highly charged solar wind ions and exospheric hydrogen atoms. The Lunar Environment Heliospheric X-ray Imager and Solar wind Magnetosphere Ionosphere Link Explorer missions are scheduled to image the Earth’s dayside magnetosphere system in soft X-rays to investigate global-scale magnetopause reconnection modes under varying solar wind conditions. The exospheric neutral hydrogen density distribution, especially the value of this density at the subsolar magnetopause is of particular interest for understanding X-ray emissions near this boundary. This paper estimates the exospheric density during solar minimum using the X-ray Multimirror Mission (XMM) astrophysics observatory. We selected an event on November-12-2008 from the XMM data archive, which detects soft X-rays of magnetosheath origin while solar wind and interplanetary magnetic field conditions are relatively constant. During the event the location of the magnetopause was measured in situ by the THEMIS mission, thus the location of the solar wind ions responsible for the magnetosheath emission is well constrained by observation. We estimated the exospheric density using the Open Geospace Global Circulation Model (OpenGGCM) and a spherically symmetric exosphere model. The ratio of the magnetosheath plasma flux between the OpenGGCM model and the THEMIS, was nearly 1, which means the magnetohydrodynamic model reasonably reproduces the magnetosheath plasma conditions. The OpenGGCM magnetosheath parameters were used to deconvolve soft X-rays of exospheric origin from the XMM signal. The lower-limit of the exospheric density of this solar minimum event is 36.8 ± 11.7 cm−3 at 10 RE subsolar location.
JGR Space Physics - 2022 - Jung - Solar Minimum Exospheric Neutral Density Near the Subsolar Magnetopause Estimated From.pdf (1.3 Mo) Télécharger le fichier
insu-03602162 , version 1 (18-08-2022)
Copyright (Tous droits réservés)
Jaewoong Jung, Hyunju K. Connor, Jennifer A. Carter, Dimitra Koutroumpa, Claudio Pagani, et al.. Solar minimum exospheric neutral density near the subsolar magnetopause estimated from the XMM soft X‐ray observations on 12 November 2008. Journal of Geophysical Research Space Physics, 2022, 127 (3), pp.e2021JA029676. ⟨10.1029/2021JA029676⟩. ⟨insu-03602162⟩
63 Consultations
40 Téléchargements
