Determining the beaming of Io decametric emissions : a remote diagnostic to probe the Io‐Jupiter interaction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Geophysical Research Space Physics Année : 2022
M. Marques
  • Fonction : Auteur
C. Louis
  • Fonction : Auteur
W. Kurth
S. Yerin
We investigate the beaming of 11 Io-Jupiter decametric (Io-DAM) emissions observed by Juno/Waves, the Nançay Decameter Array and NenuFAR. Using an up-to-date magnetic field model and three methods to position the active Io Flux Tube (IFT), we accurately locate the radiosources and determine their emission angle θ from the local magnetic field vector. These methods use (i) updated models of the IFT equatorial lead angle, (ii) ultraviolet (UV) images of Jupiter’s aurorae and (iii) multi-point radio measurements. The kinetic energy Ee− of source electrons is then inferred from θ in the framework of the Cyclotron Maser Instability. The precise position of the active IFT achieved from methods (ii,iii) can be used to test the effective torus plasma density. Simultaneous radio/UV observations reveal that multiple Io-DAM arcs are associated with multiple UV spots and provide the first direct evidence of an Io-DAM arc associated with a trans-hemispheric beam UV spot. Multi-point radio observations probe the Io-DAM sources at various altitudes, times and hemispheres. Overall, θ varies a function of frequency (altitude), by decreasing from 75° − 80° to 70° − 75° over 10 − 40 MHz with slightly larger values in the northern hemisphere, and independently varies as a function of time (or longitude of Io). Its uncertainty of a few degrees is dominated by the error on the longitude of the active IFT. The inferred values of Ee− also vary as a function of altitude and time. For the 11 investigated cases, they range from 3 to 16 keV, with a 6.6 ± 2.7 keV average.
JGR Space Physics - 2022 - Lamy - Determining the Beaming of Io Decametric Emissions A Remote Diagnostic to Probe the.pdf (4.48 Mo) Télécharger le fichier
insu-03619258 , version 1 (18-08-2022)
L. Lamy, L. Colomban, P. Zarka, R. Prangé, M. Marques, et al.. Determining the beaming of Io decametric emissions : a remote diagnostic to probe the Io‐Jupiter interaction. Journal of Geophysical Research Space Physics, 2022, 127 (4), pp.e2021JA030160. ⟨10.1029/2021JA030160⟩. ⟨insu-03619258⟩
91 Consultations
30 Téléchargements
