Adding value to randomization with qualitative analysis : the case of microcredit in rural Morocco - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue World Development Année : 2014
This paper analyzes microcredit demand and use to draw lessons on how households appropriate microcredit services. It introduces qualitative analysis to a randomized study. Findings suggest that microcredit demand and use is shaped not only by agro-ecological conditions, but by two major partially interrelated factors: debt-related norms articulated with the perception of the sanction in case of repayment default, and the "social life" of microcredit, namely, how social actors, credit officers, and local leaders, engage with microcredit. On a conceptual perspective we argue that microcredit "markets" do not result from supply confronting demand, but instead, are historical, political, and social constructs.
Guérin_WD_Last2014.pdf (562.49 Ko) Télécharger le fichier
ird-01471911 , version 1 (20-02-2017)
Solène Morvant-Roux, Isabelle Guérin, Marc Roesch, Jean-Yves Moisseron. Adding value to randomization with qualitative analysis : the case of microcredit in rural Morocco. World Development, 2014, 56, pp.302-312. ⟨10.1016/j.worlddev.2013.03.00⟩. ⟨ird-01471911⟩
503 Consultations
1467 Téléchargements
