Bonded labour, agrarian changes and capitalism : emerging patterns in South India - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Agrarian Change Année : 2013
Drawing on a number of case studies from Tamil Nadu, this paper shows that bonded labour is not a relic of the past, but surprisingly contemporary. Refuting the tenets of the semi-feudal thesis, we argue that unfree labour can go hand in hand with capitalism, and that it can be initiated and sustained by capital itself in order to accumulate surplus value. Going against the tenets of the de-proletarianization thesis, we suggest that bonded labour is not always the preferred working arrangement for capitalism. Bonded labour should be examined in connection with specific historical contexts, the changing nature of the economy, the evolution of political forces and modes of socialization. I argue that bonded labour results from a specific regime of accumulation characterized by cheap labour, increased domestic demand sustained through household debt, as well as modes of conflict, contestation and worker identity formation that engage with both governmental programmes and consumerism.
Guérin_Jac_Final2013.pdf (572.59 Ko) Télécharger le fichier
ird-01473377 , version 1 (21-02-2017)
Isabelle Guérin. Bonded labour, agrarian changes and capitalism : emerging patterns in South India. Journal of Agrarian Change, 2013, 13 (3), pp.405-423. ⟨ird-01473377⟩
299 Consultations
1310 Téléchargements
