Static Implementation of QDI Asynchronous Primitives - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
To fairly compare the performance of an asynchronous ASIC to its homologous synchronous one requires the availability of a dedicated asynchronous library. In this paper we present TAL_130nm a standard cell library dedicated to the design of QDI asynchronous circuits. Cell selection and sizing rules applied to develop TAL_130nm are detailed. It is shown that significant area and power savings as well as speed improvements can be obtained.
ark__67375_HCB-Z3VTDJGM-0.pdf (276.98 Ko) Télécharger le fichier
lirmm-00269567 , version 1 (14-09-2019)
Philippe Maurine, Jean-Baptiste Rigaud, Ghislain Fraidy Bouesse, Gilles Sicard, Marc Renaudin. Static Implementation of QDI Asynchronous Primitives. PATMOS: Power And Timing Modeling, Optimization and Simulation, Sep 2003, Turin, Italy. pp.181-191, ⟨10.1007/978-3-540-39762-5_20⟩. ⟨lirmm-00269567⟩
440 Consultations
147 Téléchargements
