Random Adjacent Sequences: An Efficient Solution for Logic BIST - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2002
High defect coverage requires good coverage of different fault types. In this paper, we present a comprehensive test vector generation technique for BIST, called Random Single Input Change (RSIC) generation, that can be used to generate tests for many arbitrary misbehaviors that can occur in digital systems, thus providing a single on-chip test generation solution. By proving the effectiveness of universal test sequences produced by such a generation technique in detecting stuck-at, path delay and bridging faults, we demonstrate that using RSIC generation is one of the best and most practical way to reach a high level of defect coverage during BIST of digital circuits.
RSIC_Generation_A_Solution_for_Logic_BIST.pdf (121.61 Ko) Télécharger le fichier
lirmm-00345802 , version 1 (19-07-2019)
René M. G. David, Patrick Girard, Christian Landrault, Serge Pravossoudovitch, Arnaud Virazel. Random Adjacent Sequences: An Efficient Solution for Logic BIST. SOC Design Methodologies, 90, Kluwer, pp.413-424, 2002, IFIP — The International Federation for Information Processing, 978-1-4757-6530-4. ⟨10.1007/978-0-387-35597-9_35⟩. ⟨lirmm-00345802⟩
284 Consultations
52 Téléchargements
