High-speed manipulation by using parallel wire-driven robots, Robotica, vol.18, pp.13-21, 2000. ,
Design and testing of an ultra-high-speed cable robot, Int. J. Robotics and Automation, vol.21, issue.1, pp.25-34, 2006. ,
A 3D spatial interface device using tensed strings, Presence, vol.3, issue.1, pp.81-86, 1994. ,
Contour-crafting-cartesiancable robot system concepts: Workspace and stiffness comparisons, Proc. ASME Int. Des. Eng. Tech. Conf. and Comp. Inf. in Eng. Conf., no. Paper DETC2008-49478, 2008. ,
Cable-driven parallel mechanisms: Application to a locomotion interface, Proc. ASME Int. Des. Eng. Tech. Conf. and Comp. Inf. in Eng. Conf., no. Paper DETC2007-35582, 2007. ,
Dexterity measure for tendon actuated parallel mechanisms, Proc. IEEE Int. Conf. Advanced Robotics, pp.1141-1146, 1991. ,
A minimal minimal linkage: The tension-compression parallel link manipulator, Proc. IMACS/SICE Int. Symp. on Robot., Mechatron., and Manuf. Syst, pp.81-88, 1993. ,
The NIST ROBOCRANE, J. Robotic Syst, vol.10, issue.5, pp.709-724, 1993. ,
Study on multiple degree-of-freedom positioning mechanism using wires (part 1) -concept, design and control, Int. J. Japan Society for Precision Eng, vol.28, issue.2, pp.131-138, 1994. ,
On the inverse kinematics, statics, and fault tolerance of cable-suspended robots, J. of Robot. Syst, vol.15, issue.10, pp.581-597, 1998. ,
A transmission index for in-parallel wiredriven mechanisms, JSME international journal, Series C, vol.41, issue.1, pp.180-187, 2001. ,
Analysis of the workspace of tendon-based stewartplatforms, 2004. ,
Planar cable-direct-driven robots: Design for wrench exertion, J. of Int. and Robot. Syst, vol.35, issue.2, pp.203-219, 2002. ,
On design of a redundant wire-driven parallel robot WARP manipulator, Proc. IEEE Int. Conf. Robotics and Automation, pp.895-900, 1999. ,
Wire-driven parallel robot: Permitting collisions between wires, The Int. J. Rob. Research, vol.27, issue.9, pp.1007-1026, 2008. ,
Legs interference checking of parallel robots over a given workspace or trajectory, Proc. IEEE Int. Conf. Robotics and Automation, pp.757-762, 2006. ,
URL : https://hal.archives-ouvertes.fr/inria-00000195
On the connections between cable-driven robots, parallel manipulators and grasping, Proc. IEEE Int. Conf. Robotics and Automation, pp.4521-4526, 2004. ,
Wrench-feasible workspace generation for cable-driven robots, IEEE Trans. on Robotics, vol.22, issue.5, pp.890-902, 2006. ,
On the design of cable-suspended planar parallel robots, ASME J. Mech. Des, vol.127, issue.5, pp.1021-1028, 2005. ,
Determination of the dynamic workspace of cable-driven planar parallel mechanisms, ASME J. Mech. Des, vol.127, issue.2, pp.242-248, 2005. ,
Analysis of the wrench-closure workspace of planar parallel cable-driven mechanisms, IEEE Trans. on Robotics, vol.22, issue.3, pp.434-445, 2006. ,
URL : https://hal.archives-ouvertes.fr/lirmm-00199376
Workspaces of cable-actuated parallel manipulators, ASME J. Mech. Des, vol.128, issue.1, pp.159-167, 2006. ,
Manipulability of a planar wire driven haptic device, Mech. and Mach. Theory, vol.37, issue.2, pp.215-228, 2002. ,
Application of the antipodal grasp Theorem to cable-driven robots, IEEE Trans. on Robotics, vol.21, issue.4, pp.713-718, 2005. ,
Force-closure workspace analysis of cable-driven parallel mechanisms, Mech. and Mach. Theory, vol.41, issue.1, pp.53-69, 2006. ,
A new methodology for the determination of the workspace of six-DOF redundant parallel structures actuated by nine wires, Robotica, vol.25, issue.1, pp.113-120, 2007. ,
A method of verifying force-closure condition for general cable manipulators with seven cables, Mech. and Mach. Theory, vol.42, issue.12, pp.1563-1576, 2007. ,
A Mathematical Introduction to Robotic Manipulation, 1994. ,
Design of reduced DOF parallel cable-based robots, Mech. and Mach. Theory, vol.39, pp.1051-1065, 2004. ,
Optimization of actuator forces in cablebased parallel manipulators using convex analysis, IEEE Trans. on Robotics, vol.24, issue.3, pp.736-740, 2008. ,
Force performance indexes for parallel mechanisms with actuation redundancy, especially for parallel wire-driven manipulators, Proc. IEEE/RSJ Int. Conf. Intelligent Robots and Systems, pp.3936-3941, 2004. ,
URL : https://hal.archives-ouvertes.fr/lirmm-00108812
Tension analysis of cable-driven parallel mechanisms, Proc. IEEE/RSJ Int. Conf. Intelligent Robots and Systems, pp.257-262, 2005. ,
On the ability of a cabledriven robot to generate a prescribed set of wrenches, Proc. ASME Int. Des. Eng. Tech. Conf. and Comp. Inf. in Eng. Conf., no. Paper DETC2008-49518, 2008. ,
Linear Optimization Problems with Inexact Data, 2006. ,
Wrench-feasible workspace of parallel cable-driven mechanisms, IEEE Int. Conf. Robotics and Automation, pp.1492-1497, 2007. ,
URL : https://hal.archives-ouvertes.fr/lirmm-00199377
Continuous workspace analysis, synthesis and optimization of wire robots, Proc. ASME Int. Des. Eng. Tech. Conf. and Comp. Inf. in Eng. Conf., no. Paper DETC2008-49532, 2008. ,
Design, analysis and realization of tendon-based parallel manipulators, Mech. and Mach. Theory, vol.40, issue.4, pp.429-445, 2005. ,
, Parallel Robots, 2006.
URL : https://hal.archives-ouvertes.fr/lirmm-00127856
Methods and Applications of Interval Analysis, SIAM Studies in Applied Mathematics, 1979. ,
Applied Interval Analysis, 2001. ,
URL : https://hal.archives-ouvertes.fr/hal-00845131
Interval Methods for Systems of Equations, 1990. ,
, Global Optimization Using Interval Analysis, 2004.
Linear Programming, 1983. ,
Safe bounds in linear and mixedinteger linear programming, Math. Programming A, vol.99, pp.283-296, 2004. ,
Consistency techniques for numeric CSPs, Proc. Inter. Joint Conf. on Artificial Intelligence (IJCAI), pp.232-238, 1993. ,
Comparing partial consistencies, Reliable Computing, vol.5, issue.3, pp.213-228, 1999. ,
ALIAS, An Algorithms Library of Interval Analysis for Equation Systems ,
Rigorous Global Search: Continuous Problems, 1996. ,
Multi-criteria optimal design of parallel manipulators based on interval analysis, Mech. and Mach. Theory, vol.40, issue.2, pp.157-171, 2005. ,
Since 2003 he is an INRIA research scientist, and currently in the CO-PRIN project-team. His research interests are in the area of robotics, analysis, design, and calibration of parallel robots. More recently, he studies interval analysis and its applications to robotics, S'03-M'06) received the B.Eng. degree in mechatronics from the Institut National des Sciences Appliquées (INSA), 2000. ,
01) is senior researcher at INRIA Sophia Antipolis -Mediterranee, where he leads the COPRIN project-team. His research interest are interval analysis (for the management of uncertainties in the design and control of robots), parallel robots and assistive robotics, Merlet was an Associate Editor of the IEEE Transactions on Robotics and is currently Associate Editor of Mechanism and Machine Theory and of the ASME Journal of Mechanisms and Robotics. He was General Chair of the 2007 IFToMM World Congress and of the 2008 IEEE/RSJ IROS Conference ,
