Timing Slack Monitoring under Process and Environmental Variations: Application to a DSP Performance Optimization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Microelectronics Journal Année : 2011
To compensate the variability effects in advanced technologies, Process, Voltage, Temperature (PVT) monitors are mandatory to use Adaptive Voltage Scaling (AVS) or Adaptive Body Biasing (ABB) techniques. This paper describes a new monitoring system, allowing failure anticipation in real-time, looking at the timing slack of a pre-defined set of observable flip-flops. This system is made of dedicated sensor structures located near monitored flip-flop, coupled with a specific timing detection window generator, embedded within the clock-tree. Validation and performances simulated in a 45 nm low power technology, demonstrate a scalable, low power and low area system, and its compatibility with a standard CAD flow. Gains between an AVFS scheme based on those structures and a standard DVFS are given for a 32 bits VLIW DSP. Keywords: Variability; Monitor; Timing slack; Process compensation
rebaud2011.pdf (3.06 Mo) Télécharger le fichier
lirmm-00607877 , version 1 (29-06-2022)
Philippe Maurine, Bettina Rebaud, Marc Belleville, Edith Beigné, Christian Bernard, et al.. Timing Slack Monitoring under Process and Environmental Variations: Application to a DSP Performance Optimization. Microelectronics Journal, 2011, 42 (5), pp.718-732. ⟨10.1016/j.mejo.2011.02.005⟩. ⟨lirmm-00607877⟩
217 Consultations
72 Téléchargements
