New interface
Journal articles
Planar graphs with $\Delta \geq 7$ and no triangle adjacent to a $C_4$ are minimally edge and total choosable
Marthe Bonamy 1 Benjamin Lévêque 2 Alexandre Pinlou 3, 4
2 G-SCOP_OC - Optimisation Combinatoire
G-SCOP - Laboratoire des sciences pour la conception, l'optimisation et la production
4 ALGCO - Algorithmes, Graphes et Combinatoire
LIRMM - Laboratoire d'Informatique de Robotique et de Microélectronique de Montpellier
Abstract : For planar graphs, we consider the problems of list edge coloring and list total coloring. Edge coloring is the problem of coloring the edges while ensuring that two edges that are adjacent receive different colors. Total coloring is the problem of coloring the edges and the vertices while ensuring that two edges that are adjacent, two vertices that are adjacent, or a vertex and an edge that are incident receive different colors. In their list extensions, instead of having the same set of colors for the whole graph, every vertex or edge is assigned some set of colors and has to be colored from it. A graph is minimally edge or total choosable if it is list $\Delta$-edge-colorable or list $(\Delta +1)$-total-colorable, respectively, where $\Delta$ is the maximum degree in the graph. It is already known that planar graphs with $\Delta \geq 8$ and no triangle adjacent to a $C_4$ are minimally edge and total choosable (Li Xu 2011), and that planar graphs with $\Delta \geq 7$ and no triangle sharing a vertex with a $C_4$ or no triangle adjacent to a $C_k (\forall 3 \leq k \leq 6)$ are minimally total colorable (Wang Wu 2011). We strengthen here these results and prove that planar graphs with $\Delta \geq 7$ and no triangle adjacent to a $C_4$ are minimally edge and total choosable.
Complete list of metadata
https://hal.inria.fr/lirmm-01347027
Contributor : Coordination Episciences Iam Connect in order to contact the contributor
Submitted on : Tuesday, August 16, 2016 - 5:08:10 PM
Last modification on : Friday, August 5, 2022 - 3:02:53 PM
File
2586-9917-1-PB.pdf
Explicit agreement for this submission
Identifiers
Citation
Marthe Bonamy, Benjamin Lévêque, Alexandre Pinlou. Planar graphs with $\Delta \geq 7$ and no triangle adjacent to a $C_4$ are minimally edge and total choosable. Discrete Mathematics and Theoretical Computer Science, 2016, Vol. 17 no. 3 (3), pp.131-146. ⟨10.46298/dmtcs.2147⟩. ⟨lirmm-01347027v2⟩
Share
Metrics
Record views
395
Files downloads
842
