Balance control in aging: improvements in anticipatory postural adjustments and updating of internal models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue BMC Geriatrics Année : 2015
Postural stability of older subjects can be estimated during orthostatic equilibrium. However, dynamic equilibrium is also important to investigate risks of fall. It implies different interpretations of measures given by force plates. Same dependant variables (e.g. center of pressure displacement) cannot be interpreted the same ways depending of the type of equilibrium that is investigated. In particular, sways increases during dynamic equilibrium and before movement execution may reflect an improvement of feedforward control.
Balance.pdf (366 Ko) Télécharger le fichier
lirmm-01348865 , version 1 (26-07-2016)
Alexandre Kubicki, France Mourey, François Bonnetblanc. Balance control in aging: improvements in anticipatory postural adjustments and updating of internal models. BMC Geriatrics, 2015, 15 (1), pp.162-164. ⟨10.1186/s12877-015-0161-6⟩. ⟨lirmm-01348865⟩
207 Consultations
367 Téléchargements
