Static Modeling of Sagging Cables With Flexural Rigidity and Shear Forces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Cables are considered perfectly flexible in the classic model-ing without flexural rigidity and with purely tangential cable forces. In this paper, a static modeling of cables is presented where flexural rigidity and shear forces are considered. The calculation details are presented with and without considering the axial extensibility of cables for three problems where one of the parameters including cable length, end point positions and forces is determined by knowing the two others. The effects of considering flexural rigidity and shear forces are then analyzed on a simple example of a cable-driven parallel robot consisting of a point mass attached to two cables.
Cable modeling_ARK2018_Hussein_vf_auteurs_HAL.pdf (263.02 Ko) Télécharger le fichier
lirmm-01897992 , version 1 (17-10-2018)
Hussein Hussein, Marc Gouttefarde, François Pierrot. Static Modeling of Sagging Cables With Flexural Rigidity and Shear Forces. ARK 2018 - 16th International Symposium on Advances in Robot Kinematics, Jul 2018, Bologna, Italy. pp.310-318, ⟨10.1007/978-3-319-93188-3_36⟩. ⟨lirmm-01897992⟩
121 Consultations
627 Téléchargements
