On the hardness of approximating Linearization of Scaffolds sharing Repeated Contigs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Solutions to genome scaffolding problems can be represented as paths and cycles in a "solution graph". However, when working with repetitions, such solution graph may contain branchings and they may not be uniquely convertible into sequences. Having introduced, in a previous work, various ways of extracting the unique parts of such solutions, we extend previously known NP-hardness results to the case that the solution graph is planar, bipartite, and subcubic, and show the APX-completeness in this case. We also provide some practical tests.
main.pdf (556.35 Ko) Télécharger le fichier
lirmm-01900395 , version 1 (22-10-2018)
lirmm-01900395 , version 2 (29-03-2019)
  • HAL Id : lirmm-01900395 , version 1
Tom Davot, Annie Chateau, Rodolphe Giroudeau, Mathias Weller. On the hardness of approximating Linearization of Scaffolds sharing Repeated Contigs. RECOMB-CG: Comparative Genomics, Oct 2018, Sherbrooke, Canada. ⟨lirmm-01900395v1⟩
178 Consultations
213 Téléchargements
