Oblivious and Semi-Oblivious Boundedness for Existential Rules - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We study the notion of boundedness in the contextof positive existential rules, that is, whether thereexists an upper bound to the depth of the chase pro-cedure, that is independent from the initial instance.By focussing our attention on the oblivious and thesemi-oblivious chase variants, we give a character-ization of boundedness in terms of FO-rewritabilityand chase termination. We show that it is decidableto recognize if a set of rules is bounded for several classes and outline the complexity of the problem.
camera_ready.pdf (234.47 Ko) Télécharger le fichier
lirmm-02148142 , version 1 (05-06-2019)
Pierre Bourhis, Michel Leclère, Marie-Laure Mugnier, Sophie Tison, Federico Ulliana, et al.. Oblivious and Semi-Oblivious Boundedness for Existential Rules. IJCAI 2019 - 28th International Joint Conference on Artificial Intelligence, Aug 2019, Macao, China. pp.1581-1587, ⟨10.24963/ijcai.2019/219⟩. ⟨lirmm-02148142⟩
322 Consultations
287 Téléchargements
