Massively Distributed Time Series Indexing and Querying - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Knowledge and Data Engineering Année : 2020
Djamel-Edine Edine Yagoubi
  • Fonction : Auteur
  • PersonId : 1086292
Reza Akbarinia
Florent Masseglia
Themis Palpanas
Indexing is crucial for many data mining tasks that rely on efficient and effective similarity query processing. Consequently, indexing large volumes of time series, along with high performance similarity query processing, have became topics of high interest. For many applications across diverse domains though, the amount of data to be processed might be intractable for a single machine, making existing centralized indexing solutions inefficient. We propose a parallel indexing solution that gracefully scales to billions of time series (or high-dimensional vectors, in general), and a parallel query processing strategy that, given a batch of queries, efficiently exploits the index. Our experiments, on both synthetic and real world data, illustrate that our index creation algorithm works on 4 billion time series in less than 5 hours, while the state of the art centralized algorithms do not scale and have their limit on 1 billion time series, where they need more than 5 days. Also, our distributed querying algorithm is able to efficiently process millions of queries over collections of billions of time series, thanks to an effective load balancing mechanism.
DPiSAX_TKDE.pdf (591.39 Ko) Télécharger le fichier
lirmm-02197618 , version 1 (30-07-2019)
Djamel-Edine Edine Yagoubi, Reza Akbarinia, Florent Masseglia, Themis Palpanas. Massively Distributed Time Series Indexing and Querying. IEEE Transactions on Knowledge and Data Engineering, 2020, 32 (1), pp.108-120. ⟨10.1109/TKDE.2018.2880215⟩. ⟨lirmm-02197618⟩
108 Consultations
636 Téléchargements
