Oblivious and Semi-Oblivious Boundedness for Existential Rules - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2020
We study the notion of boundedness in the context of positive existential rules, that is, whether there exists an upper bound to the depth of the chase procedure , that is independent from the initial instance. By focussing our attention on the oblivious and the semi-oblivious chase variants, we give a characterization of boundedness in terms of FO-rewritability and chase termination. We show that it is decidable to recognize if a set of rules is bounded for several classes and outline the complexity of the problem. This report contains the paper published at IJCAI 2019 [Bourhis et al., 2019] and an appendix with full proofs.
2006.08467-boundedness.pdf (268.15 Ko) Télécharger le fichier
lirmm-02920624 , version 1 (24-08-2020)
Pierre Bourhis, Michel Leclère, Marie-Laure Mugnier, Sophie Tison, Federico Ulliana, et al.. Oblivious and Semi-Oblivious Boundedness for Existential Rules. [Research Report] LIRMM (UM, CNRS). 2020. ⟨lirmm-02920624⟩
119 Consultations
82 Téléchargements
