Efficient Incremental Computation of Aggregations over Sliding Windows - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Computing aggregation over sliding windows, i.e., finite subsets of an unbounded stream, is a core operation in streaming analytics. We propose PBA (Parallel Boundary Aggregator), a novel parallel algorithm that groups continuous slices of streaming values into chunks and exploits two buffers, cumulative slice aggregations and left cumulative slice aggregations, to compute sliding window aggregations efficiently. PBA runs in (1) time, performing at most 3 merging operations per slide while consuming () space for windows with partial aggregations. Our empirical experiments demonstrate that PBA can improve throughput up to 4× while reducing latency, compared to state-of-the-art algorithms.
PBA_KDD_21.pdf (2.5 Mo) Télécharger le fichier
lirmm-03359490 , version 1 (30-09-2021)
Chao Zhang, Reza Akbarinia, Farouk Toumani. Efficient Incremental Computation of Aggregations over Sliding Windows. KDD 2021 - 27th ACM SIGKDD Conference on Knowledge Discovery and Data Mining, Aug 2021, Singapore (Virtual), Singapore. pp.2136-2144, ⟨10.1145/3447548.3467360⟩. ⟨lirmm-03359490⟩
79 Consultations
546 Téléchargements
