Preprints, Working Papers, ...
A graph clustering approach to localization for adaptive covariance tuning in data assimilation based on state-observation mapping
Abstract : An original graph clustering approach to efficient localization of error covariances is proposed within an ensemble-variational data assimilation framework. Here the localization term is very generic and refers to the idea of breaking up a global assimilation into subproblems. This unsupervised localization technique based on a linearized state-observation measure is general and does not rely on any prior information such as relevant spatial scales, empirical cut-off radius or homogeneity assumptions. It automatically segregates the state and observation variables in an optimal number of clusters (otherwise named as subspaces or communities), more amenable to scalable data assimilation. The application of this method does not require underlying block-diagonal structures of prior covariance matrices. In order to deal with inter-cluster connectivity, two alternative data adaptations are proposed. Once the localization is completed, an adaptive covariance diagnosis and tuning is performed within each cluster. Numerical tests show that this approach is less costly and more flexible than a global covariance tuning, and most often results in more accurate background and observations error covariances.
Complete list of metadatas
https://hal-meteofrance.archives-ouvertes.fr/meteo-02460851
Contributor : Sibo Cheng <>
Submitted on : Thursday, June 4, 2020 - 10:53:16 PM
Last modification on : Wednesday, June 24, 2020 - 2:30:09 PM
Standard.pdf
Identifiers
  • HAL Id : meteo-02460851, version 2
  • ARXIV : 2001.11860
Citation
Sibo Cheng, Jean-Philippe Argaud, Bertrand Iooss, Angélique Ponçot, Didier Lucor. A graph clustering approach to localization for adaptive covariance tuning in data assimilation based on state-observation mapping. 2020. ⟨meteo-02460851v2⟩
Share
Metrics
Record views
19
Files downloads
17
