Etude cryptographique de solution de sécurité pour les environnements distribués sans fil. Application au projet azone. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2006
Cryptographic study of security solutons for wireless distributed networks application to the azote project.
Mobile Ad hoc networks are a step closer to the vision of pervasive computing where all devices dynamically discover each other, organize communication networks between themselves and share resources/information to provide seamless service to the end-user. But providing any reliable service over such a network requires a secure and well-functioning network. Lack of infrastructure, energy-constrained nature of devices and high dynamism in the network makes the task of securing such networks quite challenging. In this thesis we propose cryptographic protocols, which are a stepping stone to a secure ad hoc network. In particular, we contribute to the areas of key establishment and secure routing in ad hoc networks. Key establishment is concerned with making available cryptographic keys to the devices, necessary for participating in the security services of the network. On the other hand routing needs to be secured in such networks as almost all nodes need to participate in the routing process (for efficiency reasons) and presence of one malicious node could easily have drastic consequences on the routing performance of the whole network. Thus security checks are required to prevent such malicious nodes from hampering the routing process and to recover from it in case they do succeed. Our rst result is a new group key agreement protocol which is especially suitable for ad hoc networks but also outperforms most known protocols for traditional networks as well. The protocol adapts well to the dynamics of the network and is robust enough to deal with message losses and link failures. It requires little self-organization by the nodes in the network. We present some modied versions of the same and security proofs showing that the security of these protocols is tightly related to the security of the Decisional Diffle-Hellman problem. We also discuss issues related to implementation of this protocol in real scenarios. Our second result is the introduction of the notion of an Aggregate Designated Verifier Signature (ADVS) scheme. An ADVS scheme allows ecient aggregation of multiple signatures on different messages designated to the same verifier. We show how this primitive can be efficiently utilized to secure reactive routing protocols in ad hoc networks. We provide a security model to analyze such schemes and propose an ADVS scheme which aggregates signatures more efficiently than existing schemes.
Les Réseaux mobiles ad hoc sont un pas de plus vers la vision de l'informatique omniprésente, où tous les dispositifs de découvrir dynamiquement les uns les autres, organiser des réseaux de communication entre eux-mêmes et de partager les ressources / informations à fournir un service intégré au l'utilisateur final. Mais fournir un service fiable dans un tel réseau nécessite une sécurité et le réseau fonctionne bien. Le manque d'infrastructures, d'énergie limitées nature de dispositifs et dynamisme élevé dans le réseau rend la tâche d'assurer de tels réseaux tout un défi. Dans cette thèse nous proposons des protocoles cryptographiques, qui sont un tremplin vers un sécurité des réseaux ad hoc. En particulier, nous contribuons à la création des zones de clés et sûr de routage dans les réseaux ad hoc. l'établissement des clés consiste à rendre disponibles clés cryptographiques pour les dispositifs, indispensable pour participer à la sécurité services du réseau. D'autre part le routage doit être fixé de telle réseaux comme presque tous les nœuds ont besoin pour participer dans le processus de routage (pour une efficacité raisons) et la présence d'un nœud malveillant peut facilement avoir des conséquences dramatiques sur la performance de routage de l'ensemble du réseau. Ainsi, les contrôles de sécurité sont nécessaires pour empêcher de tels nœuds malicieux d'entraver le processus de routage et de récupérer de là au cas où ils réussissent. Notre premier résultat est un nouveau groupe de protocole d'accord clé qui est particulièrement adapté pour réseaux ad hoc, mais surpasse également la plupart des protocoles connus pour les réseaux traditionnels ainsi. Le protocole s'adapte bien à la dynamique du réseau et est robuste assez pour faire face aux pertes de messages et les échecs lien. Il exige peu d'auto-organisation par les nœuds du réseau. Nous présentons des versions modi ed des preuves de sécurité et de montrer que même la sécurité de ces protocoles est étroitement liée à la la sécurité de la problématique décisionnelle Diffle-Hellman. Nous discutons également les questions liées à mise en œuvre de ce protocole dans des scénarios réels. Notre second résultat est l'introduction de la notion d'un vérificateur désigné globale Signature (ADVS) régime. Un système permet ADVS e? Cace agrégation de multiples signatures sur les différents messages désignés à la même vérificateur. Nous montrons comment ce primitive peut être utilisée efficacement pour garantir réactive dans les protocoles de routage ad hoc réseaux. Nous fournissons un modèle de sécurité pour analyser de tels systèmes et de proposer une régime ADVS qui signatures agrégats plus efficacement que les systèmes existants.
BHASKAR.pdf (917.19 Ko) Télécharger le fichier
pastel-00001906 , version 1 (28-07-2010)
  • HAL Id : pastel-00001906 , version 1
Raghav Bhaskar. Etude cryptographique de solution de sécurité pour les environnements distribués sans fil. Application au projet azone.. Cryptographie et sécurité [cs.CR]. Ecole Polytechnique X, 2006. Français. ⟨NNT : 2006EPXX0010⟩. ⟨pastel-00001906⟩
607 Consultations
654 Téléchargements
