]. T. Bibliographie1, S. H. Adali, and . Ardalan, Convergence and error analysis of the Fixed-Point RLS Algorithm with correlated inputs, IEEE Conference on Acoustics, Speech and Signal Processing (ICASSP'90), pp.1479-1482, 1990.
T. Adali and S. H. Ardalan, Convergence and error analysis of the fixed point RLS algorithm with correlated inputs, International Conference on Acoustics, Speech, and Signal Processing, pp.1291-1297, 1990.
DOI : 10.1109/ICASSP.1990.115681
S. T. Alexander, Transient weight misadjustment properties for the finite precision LMS algorithm, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.35, issue.9, pp.1250-1258, 1987.
DOI : 10.1109/TASSP.1987.1165279
S. H. Ardalan and S. T. Alexander, Fixed-point roundoff error analysis of the exponentially windowed RLS algorithm for time-varying systems, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.35, issue.6, pp.770-783, 1987.
DOI : 10.1109/TASSP.1987.1165207
B. Pinçon, Une introduction à Scilab, ESIAL Nancy, 2006.
P. Banerjee, D. Bagchi, M. Haldar, A. Nayak, V. Kim et al., Automatic conversion of floating point MATLAB programs into fixed point FPGA based hardware design, 11th Annual IEEE Symposium on Field-Programmable Custom Computing Machines, 2003. FCCM 2003., 2003.
DOI : 10.1109/FPGA.2003.1227262
M. Barberis and N. Shah, Migrating signal processing applications from floating-point to fixed-point. White paper, Catalytic Inc, 2004.
P. Belanovic and M. Rupp, Fixify : A Toolset for Automated Floating-point to Fixedpoint Conversion, International Conference on Computing, Communications and Control Technologies (CCCT'04), pp.28-32, 2004.
P. Belanovic and M. Rupp, Automated Floating-Point to Fixed-Point Conversion with the Fixify Environment, 16th IEEE International Workshop on Rapid System Prototyping (RSP'05), pp.172-178, 2005.
DOI : 10.1109/RSP.2005.15
M. Bellanger, Analyse des signaux et Filtrage Numérique Adaptatif, volume 1 of Collection technique et scientifique des télécommunications, 1989.
M. Bellanger, A survey of QR based fast least squares adaptive filters, IEEE International Conference on Acoustics, Speech, and Signal Processing (ICASSP'91), pp.1833-1836, 1991.
A. Benallal and A. Gilloire, Etude des effets de quantification dans les algorithmes MCR numériquement stables, Treizième colloque GRETSI, 1989.
N. J. Bershad, Comments on Comparaison of the Convergence of Two Algorithms for Adaptive FIR Digital Filters, IEEE Transactions on Acoustics, Speech, and Signal Processing, pp.1604-1606, 1985.
N. J. Bershad, Analysis of the normalized LMS algorithm with Gaussian inputs, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.34, issue.4, pp.793-806, 1986.
DOI : 10.1109/TASSP.1986.1164914
N. J. Bershad, On the probability density function of the LMS adaptive filter weights, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.37, issue.1, pp.43-55, 1989.
DOI : 10.1109/29.17499
N. J. Bershad and J. C. Bermudez, A nonlinear analytical model for the quantized LMS algorithm-the power-of-two step size case, IEEE Transactions on Signal Processing, vol.44, issue.11, pp.442895-2900, 1996.
DOI : 10.1109/78.542451
N. J. Bershad and J. C. Bermudez, A Nonlinear Analytical Model for the Quantized LMS Algorithm-The Arbitrary Step Size Case, IEEE Transactions on Signal Processing, vol.44, issue.5, pp.1175-1183, 1996.
N. J. Bershad and J. C. Bermudez, New Insights on the Transient and Steady-State Behavior of the Quantized LMS Algorithm, IEEE Transactions on Signal Processing, issue.10, pp.442623-2625, 1996.
C. Caraiscos and B. Liu, A roundoff error analysis of the LMS adaptive algorithm, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.32, issue.1, pp.34-41, 1984.
DOI : 10.1109/TASSP.1984.1164286
P. S. Chang and A. N. Willson-jr, A roundoff error analysis of the normalized LMS algorithm, Conference Record of The Twenty-Ninth Asilomar Conference on Signals, Systems and Computers, pp.1337-1341, 1996.
DOI : 10.1109/ACSSC.1995.540916
Y. H. Chang, C. K. Tzou, and N. J. Bershad, Postsmoothing for the LMS algorithm and a fixed point roundoff error analysis, IEEE Transactions on Signal Processing, vol.39, issue.4, pp.959-962, 1991.
DOI : 10.1109/78.80922
J. M. Cheneaux, L. S. Didier, and F. Rico, The fixed cadna library. Real Number and Computers, 2003.
J. M. Cheneaux and J. Vignes, Les fondements de l'arithmétique stochastique, C.R. Académie des Sciences, pp.1435-1440, 1992.
J. M. Cioffi, Limited-precision effects in adaptive filtering, IEEE Transactions on Circuits and Systems, vol.34, issue.7, pp.821-333, 1987.
DOI : 10.1109/TCS.1987.1086209
J. M. Cioffi and T. Kailath, Fast, recursive-least-squares transversal filters for adaptive filtering, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.32, issue.2, pp.304-337, 1984.
DOI : 10.1109/TASSP.1984.1164334
G. Constantinides, Perturbation analysis for word-length optimization, 11th Annual IEEE Symposium on Field-Programmable Custom Computing Machines, 2003. FCCM 2003., 2003.
DOI : 10.1109/FPGA.2003.1227244
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.385.8185
G. Constantinides, P. Cheung, and W. Luk, Truncation noise in fixed-point SFGs, Electronics Letters, vol.35, issue.23, pp.2012-2014, 1999.
DOI : 10.1049/el:19991375
G. Constantinides, P. Cheung, and W. Luk, Roundoff-noise shaping in filter design, 2000 IEEE International Symposium on Circuits and Systems. Emerging Technologies for the 21st Century. Proceedings (IEEE Cat No.00CH36353), pp.57-60, 2000.
DOI : 10.1109/ISCAS.2000.858687
G. Constantinides, P. Y. Cheung, and W. Luk, The Multiple Wordlength Paradigm, IEEE Symposium on Field-Programmable Custom Computing Machines (FFCM'01), 2001.
M. Coors, H. Keding, O. Luthje, and H. Meyr, Integer code generation for the TI TMS320C62X, 2001 IEEE International Conference on Acoustics, Speech, and Signal Processing. Proceedings (Cat. No.01CH37221), 2001.
DOI : 10.1109/ICASSP.2001.941121
M. H. Costa, J. C. Bermudez, and N. J. Bershad, Statistical analysis of the LMS algorithm with a zero-memory nonlinearity after the adaptive filter, 1999 IEEE International Conference on Acoustics, Speech, and Signal Processing. Proceedings. ICASSP99 (Cat. No.99CH36258), pp.1661-1664, 1999.
DOI : 10.1109/ICASSP.1999.756311
L. De-coster, M. Ade, R. Lauwereins, and J. A. Peperstraete, Code generation for compiled bit-true simulation of DSP applications, Proceedings. 11th International Symposium on System Synthesis (Cat. No.98EX210), 1998.
DOI : 10.1109/ISSS.1998.730590
L. H. De-figueiredo and J. Stolfi, Affine Arithmetic: Concepts and Applications, Numerical Algorithms, vol.37, issue.1-4, pp.1-13, 2003.
DOI : 10.1023/B:NUMA.0000049462.70970.b6
H. Dedieu and F. Castanie, Analyse des effets de quantification dans l'implantation de l'algorithme LMS, 1987.
P. S. Diniz and M. G. Siqueira, Fixed-point error analysis of the QR-recursive least square algorithm, IEEE Transactions on Circuits and Systems-II : Analog and Digital Signal Processing, pp.334-348, 1995.
DOI : 10.1109/82.386173
S. C. Douglas, Exact expectation analysis of the LMS adaptive filter for correlated Gaussian input data, IEEE International Conference on Acoustics Speech and Signal Processing, pp.519-522, 1993.
DOI : 10.1109/ICASSP.1993.319549
S. C. Douglas, Performance comparison of two implementations of the leaky LMS adaptive filter, IEEE Transactions on Signal Processing, vol.45, issue.8, pp.2125-2129, 1997.
DOI : 10.1109/78.611231
E. Eweda, Tracking Analysis of the Sign-Sign Algorithm for Nonstationnary Adaptive Filtering with Gaussian Data, IEEE Transactions on Signal Processing, pp.1375-1378, 1997.
E. Eweda, Transient and tracking performance bounds of the sign-sign algorithm, IEEE Transactions on Signal Processing, vol.47, issue.8, pp.2200-2210, 1999.
DOI : 10.1109/78.774763
E. Eweda, Convergence Analysis of the Sign Algorithm Without the Independance and Gaussian Assumptions, IEEE Transactions on Signal Processing, pp.2535-2543, 2000.
H. Fan, X. Q. Liu, L. Gal, and . Revisited, New Convergence Results, IEEE Transactions on Signal Processing, vol.41, pp.55-64, 1993.
C. F. Fang, T. Chen, and R. A. Rutenbar, Floating-point error analysis based on affine arithmetic, 2003 IEEE International Conference on Acoustics, Speech, and Signal Processing, 2003. Proceedings. (ICASSP '03)., pp.561-564, 2003.
DOI : 10.1109/ICASSP.2003.1202428
C. F. Fang, T. Chen, and R. A. Rutenbar, Toward efficient static analysis of finite-precision effects in DSP applications via affine arithmetic modeling, Proceedings of the 40th conference on Design automation , DAC '03, pp.496-501, 2003.
DOI : 10.1145/775832.775960
A. Feuer and E. Weinstein, Convergence analysis of LMS filters with uncorrelated Gaussian data, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.33, issue.1, pp.222-230, 1985.
DOI : 10.1109/TASSP.1985.1164493
S. Gazor and B. Farhang-boroujeny, Quantization effects in transform-domain normalized LMS algorithm, IEEE Transactions on Circuits and Systems II: Analog and Digital Signal Processing, vol.39, issue.1, pp.1-7, 1992.
DOI : 10.1109/82.204105
R. D. Gitlin, J. E. Mazo, and M. G. Taylor, On the design of gradient algorithms for digitally implemented adaptive filters, IEEE Transactions on Circuit Theory, vol.20, issue.2, pp.125-136, 1973.
DOI : 10.1109/TCT.1973.1083627
D. N. Godard, Self-Recovering Equalization and Carrier Tracking in Two-Dimensional Data Communication Systems, IEEE Transactions on Communications, vol.28, issue.11, pp.1867-1875, 1980.
DOI : 10.1109/TCOM.1980.1094608
M. Goel and N. R. Shanbhag, Finite-precision analysis of the pipelined strength-reduced adaptive filter, IEEE Transactions on Signal Processing, vol.46, issue.6, pp.1763-1769, 1998.
DOI : 10.1109/78.678521
T. Grötker, E. Multhaup, and O. Mauss, Evaluation of HW/SW Tradeoffs Using Behavioral Synthesis, 7th International Conference on Signal Processing Applications and Technology (ICSPAT'96), 1996.
R. Gupta and A. O. Hero, Transient Behaviour of Fixed-Point LMS Adaptation, IEEE Conference on Acoustics, Speech, and Signal Processing (ICASSP'00), pp.376-379, 2000.
S. Haykin, Adaptive Filter Theory, 1991.
A. Hermánek, J. Schier, and P. A. Regalia, Architecture design for FPGA implementation of finite interval CMA, European Signal Processing Conference, pp.2039-2042, 2004.
N. Hervé, D. Ménard, and O. Sentieys, Data wordlength optimization for FPGA synthesis, IEEE Workshop on Signal Processing Systems Design and Implementation, 2005., pp.623-628, 2005.
DOI : 10.1109/SIPS.2005.1579941
M. L. Honig and D. G. Messerschmidt, Convergence properties of an adaptive digital lattice filter, IEEE Transactions on Acoustics, Speech, and Signal Processing, pp.642-653, 1981.
L. L. Horowitz and K. D. Senne, Performance Advantage of Complex LMS for Controlling Narrow-Band Adaptive Arrays, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.3, pp.722-736, 1981.
K. Kalliojärvi and J. Astola, Roundoff errors in block-floating-point systems, IEEE Transactions on Signal Processing, vol.44, issue.4, pp.783-790, 1996.
DOI : 10.1109/78.492531
H. Keding, M. Willems, M. Coors, and H. Meyr, FRIDGE: a fixed-point design and simulation environment, Proceedings Design, Automation and Test in Europe, 1998.
DOI : 10.1109/DATE.1998.655893
S. Kim, K. Kum, and W. Sung, Fixed-Point Optimization Utility for C and C++ Based Digital Signal Processing Programs, Workshop on VLSI and Signal Processing '95, 1995.
S. Kim and W. Sung, Fixed-Point-Simulation Utility for C and C++ Based Digital Signal Processing Programs, Twenty-eighth Annual Asilomar Conference on Signals, Systems, and Computer, 1994.
S. Kim and W. Sung, Fixed-Point Error Analysis and Word Length Optimization of 8x8 IDCT Architectures, IEEE Transactions on Circuits and Systems for Video Technology, pp.935-940, 1998.
M. Kunt, M. Bellanger, C. De-coulon, and . Guegen, Techniques modernes de traitement numérique des signaux, volume 1 of Traitement de l'information, 1991.
P. Lapsley, J. Bier, A. Shoham, and E. A. Lee, DSP Processor Fundamentals: Architectures and Features, Berkeley Design Technology, 1996.
DOI : 10.1109/9780470544433
H. Leung and S. Haykin, Error bound method and its application to the LMS algorithm, IEEE Transactions on Signal Processing, vol.39, issue.2, pp.354-358, 1991.
DOI : 10.1109/78.80818
A. P. Livias and P. A. Regalia, On the numerical stability and accuracy of the conventional recursive least squares algorithm, IEEE Transactions on Signal Processing, vol.47, issue.1, pp.88-96, 1999.
DOI : 10.1109/78.738242
G. Long, F. Ling, and J. G. Proakis, The LMS algorithme with delayed coefficienst adaptation, IEEE Transactions on Acoustics, Speech, and Signal Processing, pp.1397-1405, 1989.
E. Martin, J. Toureilles, and C. Nouet, Conception optimisée d'architectures en précision finie pour les applications de traitement du signal, Traitement du Signal, vol.18, issue.1, pp.47-56, 2001.
. Mathworks, System-Level Design Products for DSP and communications, 2001.
V. J. Matthews, Improved convergence analysis of stochastic gradient adaptive filters using the sign algorithm, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.35, issue.4, pp.450-454, 1987.
DOI : 10.1109/TASSP.1987.1165167
V. J. Matthews and Z. Xie, Fixed-point error analysis of stochastic gradient adaptive lattice filters, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.38, issue.1, pp.70-80, 1990.
DOI : 10.1109/29.45619
K. Mayyas and T. Aboulnasr, Leaky LMS algorithm: MSE analysis for Gaussian data, IEEE Transactions on Signal Processing, vol.45, issue.4, pp.927-934, 1997.
DOI : 10.1109/78.564181
J. E. Mazo, On the Independence Theory of Equalizer Convergence, Bell System Technical Journal, vol.58, issue.5, pp.963-993, 1979.
DOI : 10.1002/j.1538-7305.1979.tb03332.x
P. Meignen, Analyse statistique de systèmes en virgule fixe, 2005.
D. Menard, Methodologie de compilation d'algorithmes de traitement du signal pour les processeurs en virgule fixe, sous contrainte de precision, 2002.
URL : https://hal.archives-ouvertes.fr/tel-00609159
D. Menard, D. Chillet, and O. Sentieys, Floating-to-Fixed-Point Conversion for Digital Signal Processors, EURASIP Journal on Applied Signal Processing, vol.37, issue.8, 2006.
DOI : 10.1155/ASP/2006/96421
URL : https://hal.archives-ouvertes.fr/inria-00459212
D. Menard, R. Rocher, P. Scalart, and O. Sentieys, SQNR determination in non-linear and non-recursive fixed-point systems, XII European Signal Processing Conference, pp.1349-1352, 2004.
URL : https://hal.archives-ouvertes.fr/inria-00482941
D. Menard and O. Sentieys, A methodology for evaluating the precision of fixed-point systems, IEEE International Conference on Acoustics, Speech, and Signal Processing, 2002.
URL : https://hal.archives-ouvertes.fr/inria-00482913
D. Menard and O. Sentieys, Automatic evaluation of the accuracy of fixed-point algorithms, Proceedings 2002 Design, Automation and Test in Europe Conference and Exhibition, 2002.
DOI : 10.1109/DATE.2002.998351
URL : https://hal.archives-ouvertes.fr/inria-00482931
A. Oppenheim and R. W. Schafer, Discrete Time Signal Processing. Prentice All Signal Processing series, 1999.
K. Ozeki and T. Umeda, An adaptive filtering algorithm using an orthogonal projection to an affine subspace and its properties, Electronics and Communications in Japan (Part I: Communications), vol.67, issue.5, pp.19-27, 1984.
DOI : 10.1002/ecja.4400670503
E. Ozer, A. P. Nisbet, and D. Gregg, Stochastic Bitwidth Approximation Using Extreme Value Theory for Customizable Processors, 2003.
S. Prakash and V. V. Rao, Fixed-point error analysis of radix-4 FFT, Signal Processing, vol.3, issue.2, pp.123-133, 1981.
DOI : 10.1016/0165-1684(81)90077-3
K. J. Raghunath and K. K. Parhi, Finite-precision error analysis of QRD-RLS and STAR-RLS adaptive filters, IEEE Transactions on Signal Processing, vol.45, issue.5, pp.1193-1209, 1997.
DOI : 10.1109/78.575694
R. Rocher, N. Herve, D. Menard, and O. Sentieys, Fixed-point Configurable Hardware Components for Adaptive Filters, 2006 IEEE International Symposium on Circuits and Systems, pp.57-60, 2006.
DOI : 10.1109/ISCAS.2006.1693331
URL : https://hal.archives-ouvertes.fr/inria-00455568
R. Rocher, D. Menard, N. Herve, and O. Sentieys, Fixed-point configurable hardware components, 2006.
URL : https://hal.archives-ouvertes.fr/inria-00455557
R. Rocher, D. Menard, P. Scalart, and O. Sentieys, Accuracy evaluation of fixed-point lms algorithm, IEEE International Conference on Acoustics, Speech, and Signal Processing, pp.237-240, 2004.
URL : https://hal.archives-ouvertes.fr/inria-00482940
R. Rocher, D. Menard, O. Sentieys, and P. Scalart, Accuracy Evaluation of Fixed-Point APA algorithm, Proceedings. (ICASSP '05). IEEE International Conference on Acoustics, Speech, and Signal Processing, 2005., pp.57-60, 2005.
DOI : 10.1109/ICASSP.2005.1416239
URL : https://hal.archives-ouvertes.fr/inria-00482702
S. Roy and P. Banerjee, An algorithm for converting floating-point computations to fixedpoint in matlab based fpga design, Design Automation Conference, pp.484-487, 2004.
S. Roy and P. Banerjee, An algorithm for trading off quantization error with hardware resources for matlab-based fpga design, IEEE Transactions on Computers, pp.886-896, 2005.
C. G. Samson and V. U. Reddy, Fixed-Point Error Analysis of the Normalized Ladder Algorithm, IEEE Transactions on Acoustics, Speech, and Signal Processing, pp.1177-1191, 1983.
S. D. Sankaran and A. A. Beex, Convergence behavior of affine projection algorithms, IEEE Transactions on Signal Processing, vol.48, issue.4, pp.1086-1096, 2000.
DOI : 10.1109/78.827542
E. H. Satorius and S. T. Alexander, Channel Equalization using adaptive lattice filters, IEEE Transactions on Communications, pp.899-905, 1979.
H. E. Satorius, S. W. Larisch, S. C. Lee, and L. J. Griffiths, Fixed-point implementation of adaptive digital filters, ICASSP '83. IEEE International Conference on Acoustics, Speech, and Signal Processing, pp.33-36, 1983.
DOI : 10.1109/ICASSP.1983.1172170
A. H. Sayed and H. C. Shin, Transient behavior of Affine Projections Algorithms, IEEE International Conference on Acoustics, Speech, and Signal Processing, pp.90-102, 2004.
R. Serizel, Implantation en virgule fixe d'un codeur audio, 2006.
M. J. Shensa, Recursive Least-Square Lattice Algorithms, IEEE Transactions on Automatic Control, pp.695-702, 1981.
D. T. Sherwood and N. J. Bershad, Quantization effects in the complex LMS adaptive algorithm-linearization using dither-applications, IEEE Transactions on Circuits and Systems, vol.35, issue.4, pp.466-470, 1988.
DOI : 10.1109/31.1767
C. Shi, Statistical method for floating-point conversion, 2002.
C. Shi, Floating-point to Fixed-point Conversion, 2004.
C. Shi and R. W. Bodersen, An automated floating-point to fixed-point conversion methodology, IEEE International Conference on Acoustics, Speech, and Signal Processing (ICASSP'03), pp.529-532, 2003.
C. Shi and R. W. Bodersen, A perturbation theory on statistical quantization effects in fixed-point DSP with non-stationary inputs, IEEE International Symposium on Circuits and Systems (ISCAS'04), 2004.
D. T. Slock, On the convergence behavior of the LMS and the normalized LMS algorithms, IEEE Transactions on Signal Processing, vol.41, issue.9, pp.2811-2825, 1993.
DOI : 10.1109/78.236504
G. R. Sohie and L. H. Sibul, Stochastic convergence properties of the adaptive gradient lattice, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.32, issue.1, pp.102-107, 1984.
DOI : 10.1109/TASSP.1984.1164274
V. Solo, The limiting behavior of LMS, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.37, issue.12, pp.1909-1922, 1989.
DOI : 10.1109/29.45537
V. Solo, The error variance of LMS with time-varying weights, IEEE Transactions on Signal Processing, vol.40, issue.4, pp.803-813, 1992.
DOI : 10.1109/78.127953
A. Sripad and D. L. Snyder, A necessary and sufficient condition for quantization errors to be uniform and white, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.25, issue.5, pp.442-448, 1977.
DOI : 10.1109/TASSP.1977.1162977
. Synopsys, Converting ANSI-C into Fixed-Point using CoCentric Fixe-Point Designer, Synopsys Inc, 2000.
M. Tarrab and A. Feuer, Convergence and performance analysis of normalized LMS Filters with Uncorrelated Gaussian Data, IEEE Transactions on Information Theory, vol.334, issue.4, pp.680-691, 1988.
L. Tizani, Implantation en virgule fixe d'un recepteur de radiocommunication WCDMA, 2006.
J. M. Toureilles, Conception d'architectures pour le traitement du signal en précision finie, 1999.
R. Uribe and T. Cesear, A methodology for exploring finite-precision effects when solving linear systems of equations with least-squares techniques in fixed-point hardware, Proceedings of the Ninth Annual Workshop on High Performance Embedded Computing (HPEC'05), 2005.
S. Wadekar and A. Parker, Accuracy sensitive word-length selection for algorithm optimization, Proceedings International Conference on Computer Design. VLSI in Computers and Processors (Cat. No.98CB36273), pp.54-61, 1998.
DOI : 10.1109/ICCD.1998.727023
B. Widrow, A Study of Rough Amplitude Quantization by Means of Nyquist Sampling Theory, IRE Transactions on Circuit Theory, vol.3, issue.4, pp.266-276, 1956.
DOI : 10.1109/TCT.1956.1086334
B. Widrow, Statistical analysis of amplitude-quantized sampled-data systems, Transactions AIEE, Part. II:Applications and Industry, pp.555-568, 1960.
DOI : 10.1109/TAI.1961.6371702
B. Widrow, Stationary and nonstationary learning characteristics of the LMS adaptive filter, Proceedings of the IEEE, vol.64, issue.8, pp.1151-1162, 1976.
DOI : 10.1109/PROC.1976.10286
B. Widrow, I. Kollár, and M. Liu, Statistical theory of quantization, IEEE Transactions on Instrumentation and Measurement, vol.45, issue.2, pp.353-361, 1996.
DOI : 10.1109/19.492748
N. R. Yousef and A. H. Sayed, Tracking Analysis of the LMF and LMMN Adaptive Algorithms . Asilomar, pp.786-790, 1999.
N. R. Yousef and A. H. Sayed, Fixed-point steady-state analysis of adaptive filters, International Journal of Adaptive Control and Signal Processing, vol.46, issue.3, pp.237-258, 2003.
DOI : 10.1002/acs.738
X. H. Yu, A new numerically stable structure for fast RLS adaptive filtering, International Conference on Acoustics, Speech, and Signal Processing, pp.1409-1412, 1990.
DOI : 10.1109/ICASSP.1990.115653
U. Zölzer-]-r, D. Rocher, N. Menard, O. Herve, and . Sentieys, Digital Audio Signal Processing Publications Revues internationales Fixed-Point Configurable Hardware Components, Eurasip Journal on Embedded Systems (JES), issue.1, pp.1-13, 1997.
D. Menard, R. Rocher, O. Sentieys, R. Rocher, D. Menard et al., Automatic Accuracy Evaluation for DSP Fixed- Point Linear Systems Accuracy Evaluation of Fixed-Point LMS Algorithm, Submitted to the Journal Theoretical Computer Science International Conference on Acoustics, Speech and Signal Processing, pp.237-240, 2004.
D. Menard, R. Rocher, P. Scalart, O. Sentieys, R. Rocher et al., SQNR determination in non-linear and non-recursive fixed-point systems Accuracy Evaluation of Fixed-Point APA Algorithms, XII European Signal Processing Conference International Conference on Acoustics, Speech and Signal Processing 2005 (ICASSP 2005) Fixed-Point Configurable Hardware Components for Adaptive Filters In IEEE International Symposium on Circuits and Systems, pp.1349-1352, 2004.
]. R. Conférence-nationale7, D. Rocher, O. Menard, P. Sentieys, and . Scalart, Evaluation de la précision des Algorithmes de Projection Affine en Virgule Fixe, 20ème20`20ème colloque GRETSI sur le traitement du signal et des images, 2005.
