Abstract : Hadrontherapy is a recent and particularly attractive modality. Characterized by a specific dose deposition profile in matter and by a high biological effectiveness, ions are found to be very well-suited for cancer treatment. As an emergent modality, the research in hadrontherapy is extremely active and promises many improvements for the future. However, there is no tool to date to quantify the clinical benefit for the patient related to the proposed improvements, the use of a gantry for example. In this work, we propose to use the treatment planning system, usually dedicated to clinical practice, in a prospective purpose. Suppressing the classical constraints of precision and time, our optimization method is based on a genetic algorithm designed to approach a global solution including a high number of balistic parameters (free irradiation fields) for all regions of dosimetric interest. The optimization strategy is progressively complicated in order to efficientely take into account the main issues of the inverse planning problem. The robustness of plans towards the uncertainties related to the application of the treatment, essential in hadrontherapy, is evaluated. The results show that the inclusion, in the optimization, of parameters usually fixed by the human planner leads systematically to an improved treatment quality. The final product of this work is a prospective optimization tool characterized by an easy set-up system and the ability to perform comparative studies on the relevance of new irradiation modalities.
Résumé : L'hadronthérapie est une modalité d'irradiation récente particulièrement attractive. Les ions, par leur profil caractéristique de dépôt de dose dans la matière et leur efficacité biologique accrue, sont des particules parfaitement adaptées pour le traitement du cancer. C’est une modalité émergente et les travaux de recherche et de développement qui en font l'objet se poursuivent de manière soutenue. Cependant, il n'existe à ce jour aucun outil permettant de quantifier pour le patient le gain clinique associé aux améliorations proposées, comme l’apport d’une gantry par exemple. Nous proposons dans ce travail de concevoir un module de planification inverse du traitement pour un but prospectif. Détachée des contraintes usuelles de précision et de temps de calcul, notre méthode d'optimisation se base sur un algorithme génétique afin d'approcher d'une solution globale vis-à-vis d'un grand nombre de paramètres balistiques (champs d’irradiation libres) et en associant les diverses régions d'intérêt dosimétrique. La stratégie d'optimisation retenue est progressivement complexifiée afin de prendre en compte de manière efficace les différents enjeux de la planification. La robustesse du plan vis-à-vis des incertitudes inhérentes au traitement, primordiale en hadronthérapie, est évaluée. Dans toutes les situations testées, il apparaît que l'inclusion dans l'optimisation de paramètres habituellement fixés manuellement permet une amélioration de la qualité de traitement. Nous proposons au terme de cette étude un outil prospectif d'optimisation au réglage simple et capable de mener des études comparées sur la pertinence de nouvelles modalités d’irradiation.
