The inverse scattering trasformfourier analysis for non linear problems, Studies in Applied Mathematics, pp.249-315, 1974. ,
Inverse problems for quantum trees Inverse problems and imaging web, pp.1-21, 2008. ,
Inverse problems for quantum trees II: Recovering matching conditions for star graphs, Inverse Problems and Imaging, vol.4, issue.4, pp.579-598, 2010. ,
DOI : 10.3934/ipi.2010.4.579
On an inverse problem for tree-like networks of elastic strings, ZAMM, vol.21, issue.1, pp.136-150, 2010. ,
DOI : 10.1002/zamm.200900295
Boundary spectral inverse problem on a class of graphs (trees) by the BC method, Inverse Problems, vol.20, issue.3, pp.642-672, 2004. ,
DOI : 10.1088/0266-5611/20/3/002
Inverse problems on graphs: recovering the tree of strings by the BC-method, Journal of Inverse and Ill-posed Problems, vol.14, issue.1, pp.29-46, 2006. ,
DOI : 10.1515/156939406776237474
INVARIANT IMBEDDING AND THE REDUCTION OF TWO-POINT BOUNDARY VALUE PROBLEMS TO INITIAL VALUE PROBLEMS, Proceedings of the National Academy of Sciences, vol.46, issue.12, pp.1646-1649, 1960. ,
DOI : 10.1073/pnas.46.12.1646
An introduction to invariant imbedding, Society for Industrial Mathematics, 1992. ,
Almost periodic functions, 1954. ,
Eine Umkehrung der Sturm-Liouvilleschen Eigenwertaufgabe: Bestimmung der Differentialgleichung durch die Eigenwerte, Acta Mathematica, vol.78, issue.0, pp.1-96, 1946. ,
DOI : 10.1007/BF02421600
On the passivity criterion for ltiN-ports, International Journal of Circuit Theory and Applications, vol.19, issue.4, pp.323-333, 1982. ,
DOI : 10.1002/cta.4490100404
Inverse spectral problem for a star graph of stieltjes strings, Methods Funct. Anal. Topology, vol.14, pp.148-151, 2008. ,
Adjoint and self-adjoint differential operators on graphs, Electronic Journal of Differential Equations, vol.6, pp.1-10, 1998. ,
Inverse eigenvalue problems on directed graphs, Transactions of the American Mathematical Society, vol.351, issue.10, pp.4069-4088, 1999. ,
DOI : 10.1090/S0002-9947-99-02175-3
Integral equations and application, 2008. ,
DOI : 10.1017/CBO9780511569395
Inverse scattering on the line, Communications on Pure and Applied Mathematics, vol.45, issue.2, pp.121-251, 1979. ,
DOI : 10.1002/cpa.3160320202
Properties of the s-matrix of the one-dimensional schrödinger equation, Trduy Mat. Inst. Steklov, vol.73, pp.314-333, 1964. ,
Inverse Sturm-Liouville problems and their applications, 2008. ,
Conversions between S, Z, Y, h, ABCD, and T parameters which are valid for complex source and load impedances. Microwave Theory and Techniques, IEEE Transactions on, vol.42, issue.2, pp.205-211, 1994. ,
Frequency domain reflectometry for on board testing of aging aircraft wiring, IEEE Trans. EMC, issue.2, p.45, 2003. ,
An inexpensive distance measuring system for navigation of robotic vehicle. Microwave Opt, Technol. Lett, vol.33, issue.2, pp.84-97, 2002. ,
Method for Solving the Korteweg-deVries Equation, Physical Review Letters, vol.19, issue.19, pp.1095-1098, 1967. ,
DOI : 10.1103/PhysRevLett.19.1095
Inverse scattering problem on a noncompact graph, Theoretical and Mathematical Physics, vol.55, issue.2, pp.230-240, 1988. ,
DOI : 10.1007/BF01017484
Scattering problems on noncompact graphs, Theoretical and Mathematical Physics, vol.73, issue.3, pp.345-359, 1988. ,
DOI : 10.1007/BF01016616
The invisible fray: a critical analysis of the use of reflectometry for fray location, IEEE Sensors Journal, vol.6, issue.3, 2006. ,
DOI : 10.1109/JSEN.2006.874017
Can one hear the shape of a graph?, Journal of Physics A: Mathematical and General, vol.34, issue.31, p.34, 2001. ,
DOI : 10.1088/0305-4470/34/31/301
S-parameters technique for faster, more accurate network design, 1996. ,
An Inverse Sturm???Liouville Problem with Mixed Given Data, SIAM Journal on Applied Mathematics, vol.34, issue.4, pp.676-680, 1978. ,
DOI : 10.1137/0134054
transmission lines, Journal of Mathematical Physics, vol.23, issue.12, pp.2286-2290, 1982. ,
DOI : 10.1063/1.525307
Adaptive method and apparatus for transmission line analysis. U.S, 2002. ,
Perturbation Theory for Linear Operators, 1980. ,
The inverse scattering problems for transmission lines, pp.6-8, 1972. ,
The determination of the scattering potential from the spectral measure function,iii: Calculation of the scattering potential from the scattering operator for the one-dimensional schrödinger equation, Nuovo Cimento, vol.10, pp.276-304, 1956. ,
Scattering theory. Notes de cours, 2006. ,
Inverse spectral problem for quantum graphs, Journal of Physics A: Mathematical and General, vol.38, issue.22, p.38, 2005. ,
DOI : 10.1088/0305-4470/38/22/014
Geometric properties of quantum graphs and vertex scattering matrices, Opuscula Mathematica, vol.30, issue.3, 2007. ,
DOI : 10.7494/OpMath.2010.30.3.295
On the inverse scattering problem on branching graphs, Journal of Physics A: Mathematical and General, vol.35, issue.1, 2002. ,
DOI : 10.1088/0305-4470/35/1/309
Power waves and the scattering matrix. Microwave Theory and Techniques, IEEE Transactions on, vol.13, issue.2, 1965. ,
Integrals of nonlinear equations of evolution and solitary waves, Communications on Pure and Applied Mathematics, vol.15, issue.5, pp.467-490, 1968. ,
DOI : 10.1002/cpa.3160210503
Distributed Reflectometry Method for Wire Fault Location Using Selective Average, IEEE Sensors Journal, vol.10, issue.2, pp.300-310, 2010. ,
DOI : 10.1109/JSEN.2009.2033946
Inverse Sturm-Lioville Problems, 1987. ,
Inverse scattering for the matrix Schrödinger operator and Schrödinger operator on graphs with general self-adjoint boundary conditions, ANZIAM J, vol.43, pp.1-8, 2002. ,
Inverse scattering on matrices with boundary conditions, Journal of Physics A: Mathematical and General, vol.38, issue.22, pp.4875-4885, 2005. ,
DOI : 10.1088/0305-4470/38/22/012
URL : http://arxiv.org/abs/math-ph/0702073
Non-intrusive impedance-based cable tester, U.S. Patent, vol.5, pp.977-773, 1999. ,
Transmission Lines and Lumped circuits, 2001. ,
Inverse Problem for the Sturm--Liouville Equation on a Simple Graph, SIAM Journal on Mathematical Analysis, vol.32, issue.4, pp.801-819, 2000. ,
DOI : 10.1137/S0036141000368247
Ambartsumyan's theorem for the Sturm-Liouville boundary value problem on a star-shaped graph, Funct. Anal. Topology, vol.14, pp.159-167, 2005. ,
Inverse problem for the Sturm???Liouville equation on a star-shaped graph, Mathematische Nachrichten, vol.26, issue.13-14, pp.1595-1619, 2007. ,
DOI : 10.1002/mana.200410567
Microwave engineering, 2005. ,
Power waves and conjugate matching. Circuits and Systems II: Express Briefs, IEEE Transactions on, vol.55, issue.1, pp.92-96, 2008. ,
Matrix differential equations, Bulletin of the American Mathematical Society, vol.81, issue.2, pp.485-488, 1975. ,
DOI : 10.1090/S0002-9904-1975-13793-1
Differential equations in operator algebras, Mathematische Annalen, vol.28, issue.2, pp.97-110, 1979. ,
DOI : 10.1007/BF01420367
RATIONAL APPROXIMATIONS TO ALGEBRAIC NUMBERS, Mathematika, vol.2, pp.1-20, 1955. ,
DOI : 10.1142/9789812385215_0009
Detection and location of defects in wiring networks using time domain reflectometry and neural networks, Field Computation (CEFC), vol.5, pp.1502-1505, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00555222
Detection of Defects in Wiring Networks Using Time Domain Reflectometry, IEEE Transactions on Magnetics, vol.46, issue.8, pp.462998-3001, 2010. ,
DOI : 10.1109/TMAG.2010.2043720
URL : https://hal.archives-ouvertes.fr/hal-00504997
Decoupling Order Reduction via the Riccati Transformation, SIAM Review, vol.29, issue.1, pp.91-113, 1987. ,
DOI : 10.1137/1029003
Analysis of spread spectrum time domain reflectometry for wire fault location, IEEE Sensors Journal, vol.5, issue.6, pp.1469-1478, 2005. ,
DOI : 10.1109/JSEN.2005.858964
Superposition laws for solutions of differential matrix Riccati equations arising in control theory, IEEE Transactions on Automatic Control, vol.30, issue.3, pp.266-272, 1985. ,
DOI : 10.1109/TAC.1985.1103934
An Inverse Scattering Approach to Soft Fault Diagnosis in Lossy Electric Transmission Lines, Antennas and Propagation Society International Symposium (APSURSI), Accepted, 2010. ,
DOI : 10.1109/TAP.2011.2163772
URL : https://hal.archives-ouvertes.fr/hal-00777454
Some inverse scattering problems on star-shaped graphs, Journal of Mathematical Analysis and Applications, vol.378, issue.1, pp.343-358, 2011. ,
DOI : 10.1016/j.jmaa.2010.12.047
URL : https://hal.archives-ouvertes.fr/inria-00548917
Can one hear the shape of a network? Partial Differential Eqs on multidimensional structures in Lect, Notes in Math, vol.219, pp.19-36, 2001. ,
Using Frequency Domain Reflectometry for Water Level Measurement, 2000. ,
Bounded real scattering matrices and the foundations of linear passive network theory. Circuit Theory, IRE Transactions on, vol.6, issue.1, pp.102-124, 1959. ,
Inverse spectral problems for Sturm???Liouville operators on graphs, Inverse Problems, vol.21, issue.3, pp.1075-1086, 2005. ,
DOI : 10.1088/0266-5611/21/3/017
An inverse problem for higher order differential operators on star-type graphs, Inverse Problems, vol.23, issue.3, pp.893-903, 2007. ,
DOI : 10.1088/0266-5611/23/3/003
Inverse problems for Sturm-Liouville operators on graphs with a cycle, Operators and Matrices, vol.2, issue.4, pp.543-553, 2008. ,
DOI : 10.7153/oam-02-34
Exact theroy of two-dimensional self-focusing and one-dimensional self-modulation of waves in nonlinear media, Soviet Physics Jetp, vol.34, issue.1, pp.62-69, 1972. ,
Inverse Scattering for Soft Fault Diagnosis in Electric Transmission Lines, 48th IEEE Conference on decision and Control, 2009. ,
DOI : 10.1109/TAP.2010.2090462
URL : https://hal.archives-ouvertes.fr/inria-00365991
Wave propagation, Observation and Control in 1-D flexible multi-structures, 2006. ,
