PE-Assembler: de novo assembler using short paired-end reads, Bioinformatics, vol.27, issue.2, pp.167-182, 2011. ,
DOI : 10.1093/bioinformatics/btq626
ARACHNE: A Whole-Genome Shotgun Assembler, Genome Research, vol.12, issue.1 ,
DOI : 10.1101/gr.208902
Scaffolding pre-assembled contigs using SSPACE, Bioinformatics, vol.27, issue.4, pp.578-2011 ,
DOI : 10.1093/bioinformatics/btq683
Ray: Simultaneous Assembly of Reads from a Mix of High-Throughput Sequencing Technologies, Journal of Computational Biology, vol.17, issue.11, pp.1519-1533, 2010. ,
DOI : 10.1089/cmb.2009.0238
QSRA ??? a quality-value guided de novo short read assembler, BMC Bioinformatics, vol.10, issue.1, pp.69-75, 2009. ,
DOI : 10.1186/1471-2105-10-69
ALLPATHS: de novo assembly of wholegenome shotgun microreads, Genome Research, vol.18, issue.82, pp.810-820, 2008. ,
De novo fragment assembly with short mate-paired reads: Does the read length matter?, Genome Research, vol.19, issue.2, pp.336-346, 2009. ,
DOI : 10.1101/gr.079053.108
Meraculous: De Novo Genome Assembly with Short Paired-End Reads, PLoS ONE, vol.21, issue.8, pp.23501-23516, 2011. ,
DOI : 10.1371/journal.pone.0023501.s003
Parallel and memory-efficient reads indexing for genome assembly, PBC, vol.64, pp.58-112, 2011. ,
URL : https://hal.archives-ouvertes.fr/inria-00637536
Paired-end read length lower bounds for genome re-sequencing, BMC Bioinformatics, vol.10, issue.Suppl 13, pp.2-111, 2009. ,
DOI : 10.1186/1471-2105-10-S13-O2
URL : https://hal.archives-ouvertes.fr/inria-00426856
Localized Genome Assembly from Reads to Scaffolds: Practical Traversal of the Paired String Graph, Algorithms in Bioinformatics, vol.18, issue.5, pp.39-48, 2011. ,
DOI : 10.1101/gr.074492.107
URL : https://hal.archives-ouvertes.fr/inria-00637535
Succinct data structures for assembling large genomes, Bioinformatics, vol.27, issue.4, pp.479-57, 2011. ,
DOI : 10.1093/bioinformatics/btq697
URL : http://arxiv.org/abs/1008.2555
Jigsaw puzzles, edge matching, and polyomino packing: Connections and complexity. Graphs and Combinatorics, pp.195-208, 2007. ,
DOI : 10.1007/s00373-007-0713-4
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.108.3689
Hapsembler: An Assembler for Highly Polymorphic Genomes, Research in Computational Molecular Biology, pp.38-52 ,
DOI : 10.1007/978-3-642-20036-6_5
Assemblathon 1: A competitive assessment of de novo short read assembly methods, Genome Research, vol.21, issue.12, pp.88-96, 2011. ,
DOI : 10.1101/gr.126599.111
URL : https://hal.archives-ouvertes.fr/inria-00637571
Matching, Euler tours and the Chinese postman, Mathematical Programming, vol.1, issue.Suppl. 1, pp.88-124, 1973. ,
DOI : 10.1007/BF01580113
Indexing compressed text, Journal of the ACM, vol.52, issue.4, pp.552-581, 2005. ,
DOI : 10.1145/1082036.1082039
Opera: reconstructing optimal genomic scaffolds with high-throughput paired-end sequences, Research in Computational Molecular Biology, pp.437-451 ,
DOI : 10.1089/cmb.2011.0170
URL : http://www.ncbi.nlm.nih.gov/pmc/articles/PMC3216105
High-quality draft assemblies of mammalian genomes from massively parallel sequence data, Proceedings of the National Academy of Sciences, vol.108, issue.4, pp.1513-2011 ,
DOI : 10.1073/pnas.1017351108
Crystallizing short-read assemblies around seeds, BMC Bioinformatics, vol.10, issue.Suppl 1, pp.16-49, 2009. ,
DOI : 10.1186/1471-2105-10-S1-S16
URL : http://doi.org/10.1186/1471-2105-10-s1-s16
The greedy path-merging algorithm for contig scaffolding, Journal of the ACM, vol.49, issue.5, pp.603-615, 2002. ,
DOI : 10.1145/585265.585267
Parallel short sequence assembly of transcriptomes, BMC Bioinformatics, vol.10, issue.Suppl 1, pp.14-57, 2009. ,
DOI : 10.1186/1471-2105-10-S1-S14
Computers and intractability: A guide to the theory of NP-completeness. Freeman&Co, p.32, 1979. ,
Simple Linear Work Suffix Array Construction ,
DOI : 10.1007/3-540-45061-0_73
Quake: quality-aware detection and correction of sequencing errors, Genome Biology, vol.11, issue.11, pp.116-2010 ,
DOI : 10.1101/gr.088013.108
Large-scale assembly of DNA strings and space-efficient construction of suffix trees, Proceedings of the twenty-seventh annual ACM symposium on Theory of computing, pp.169-177, 1995. ,
Efficient parallel and out of core algorithms for constructing large bi-directed de Bruijn graphs, BMC Bioinformatics, vol.11, issue.1, pp.560-2010 ,
DOI : 10.1186/1471-2105-11-560
The Sequence Alignment/Map format and SAMtools, Bioinformatics, vol.25, issue.16, pp.252078-83, 2009. ,
DOI : 10.1093/bioinformatics/btp352
De novo assembly of human genomes with massively parallel short read sequencing, Genome Research, vol.20, issue.2, pp.265-313, 2010. ,
DOI : 10.1101/gr.097261.109
The future of personal genomics, Science, issue.5845 8, p.3171687, 2007. ,
Computability of Models for Sequence Assembly, Algorithms in Bioinformatics, vol.34, pp.289-301, 2007. ,
DOI : 10.1007/978-3-540-74126-8_27
Paired de bruijn graphs: a novel approach for incorporating mate pair information into genome assemblers, Research in Computational Molecular Biology, pp.238-251 ,
Assembly algorithms for next-generation sequencing data, Genomics, vol.95, issue.6, pp.315-327, 2010. ,
DOI : 10.1016/j.ygeno.2010.03.001
URL : http://doi.org/10.1016/j.ygeno.2010.03.001
Probability and computing: Randomized algorithms and probabilistic analysis, p.102, 2005. ,
DOI : 10.1017/CBO9780511813603
Toward Simplifying and Accurately Formulating Fragment Assembly, Journal of Computational Biology, vol.2, issue.2, pp.275-290, 1995. ,
DOI : 10.1089/cmb.1995.2.275
Parametric Complexity of Sequence Assembly: Theory and Applications to Next Generation Sequencing, Journal of Computational Biology, vol.16, issue.7, pp.897-908, 2009. ,
DOI : 10.1089/cmb.2009.0005
Practical entropy-compressed rank/select dictionary . Arxiv preprint cs/0610001, p.57, 2006. ,
DOI : 10.1137/1.9781611972870.6
URL : http://arxiv.org/abs/cs/0610001
IDBA ??? A Practical Iterative de Bruijn Graph De Novo Assembler, Research in Computational Molecular Biology, pp.426-440 ,
DOI : 10.1007/978-3-642-12683-3_28
Mapsembler, targeted and micro assembly of large NGS datasets on a desktop computer, BMC Bioinformatics, vol.13, issue.1, pp.48-76, 2012. ,
DOI : 10.1186/gb-2011-12-1-r6
URL : https://hal.archives-ouvertes.fr/hal-00784408
Hierarchical Scaffolding With Bambus, Genome Research, vol.14, issue.1 ,
DOI : 10.1101/gr.1536204
URL : http://www.ncbi.nlm.nih.gov/pmc/articles/PMC314292
Genome sequence assembly: algorithms and issues, Computer, vol.35, issue.7, pp.47-54, 2002. ,
DOI : 10.1109/MC.2002.1016901
-ary trees, prefix sums and multisets, ACM Transactions on Algorithms, vol.3, issue.4, pp.43-57, 2007. ,
DOI : 10.1145/1290672.1290680
URL : https://hal.archives-ouvertes.fr/hal-01087676
GAGE: A critical evaluation of genome assemblies and assembly algorithms, Genome Research, vol.22, issue.3, pp.2011-109 ,
DOI : 10.1101/gr.131383.111
DNA sequencing with chain-terminating inhibitors, Proceedings of the National Academy of Sciences, vol.74, issue.12, pp.5463-5470, 1977. ,
DOI : 10.1073/pnas.74.12.5463
URL : http://www.ncbi.nlm.nih.gov/pmc/articles/PMC431765
A fast hybrid short read fragment assembly algorithm, Bioinformatics, vol.25, issue.17, pp.2279-75, 2009. ,
DOI : 10.1093/bioinformatics/btp374
ALLPATHS 2: small genomes assembled accurately and with high continuity from short paired reads, Genome Biology, vol.10, issue.87, pp.103-63, 2009. ,
Next-generation DNA sequencing, Nature Biotechnology, vol.105, issue.10, pp.1135-1145, 2008. ,
DOI : 10.1038/nbt1486
Efficient construction of an assembly string graph using the FM-index, Bioinformatics, vol.26, issue.12, pp.367-416, 2010. ,
DOI : 10.1093/bioinformatics/btq217
ABySS: A parallel assembler for short read sequence data, Genome Research, vol.19, issue.6, pp.1117-1123, 2009. ,
DOI : 10.1101/gr.089532.108
Aggressive assembly of pyrosequencing reads with mates, Bioinformatics, issue.24, pp.242818-2824, 2008. ,
Assembling millions of short DNA sequences using SSAKE, Bioinformatics, vol.23, issue.4, pp.500-501, 2007. ,
DOI : 10.1093/bioinformatics/btl629
Assessing the benefits of using mate-pairs to resolve repeats in de novo short-read prokaryotic assemblies, BMC Bioinformatics, vol.12, issue.1, pp.95-2011 ,
DOI : 10.4056/sigs.761490
String Matching in DNA Sequences: Implications for Short Read Sequencing and Repeat Visualisation, p.29, 2007. ,
An analysis of the feasibility of short read ,
