Priority Encoding Transmission, IEEE Transactions on Information Theory, vol.42, issue.6, 1996. ,
DOI : 10.1109/sfcs.1994.365731
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.22.8116
IGMP/MLD-Based Explicit Membership Tracking Function for Multicast Work in Progress: <draft-ietf-pim-explicit-tracking-05>, IETF PIM Working Group, 2013. ,
Low-Density Parity-Check Codes and Their Rateless Relatives, IEEE Communications Surveys & Tutorials, vol.13, issue.1, pp.3-26, 2011. ,
DOI : 10.1109/SURV.2011.040410.00042
Dependency-aware unequal erasure protection codes, Journal of Zhejiang University-SCIENCE A, vol.7, issue.S1, 2006. ,
DOI : 10.1631/jzus.2006.AS0027
About priority encoding transmission, IEEE Transactions on Information Theory, vol.46, issue.2, 2000. ,
DOI : 10.1109/18.825846
166 codes al-fec et protocoles de diffusion robuste de contenus Generalized low density (tanner) codes, IEEE International Conference on Communications (ICC'99), 1999. ,
Requirements for Internet Hosts ? Communication Layers, IETF Request for Comments RFC, vol.1122, 1989. ,
DOI : 10.17487/rfc1122
Automatic Multicast Tunneling, 2013. ,
DOI : 10.17487/rfc7450
A Digital Fountain Approach to Reliable Distribution of Bulk Data, SIG- COMM Computer Communication Review, vol.28, issue.4, 1998. ,
Survey of error recovery techniques for IP-based audio-visual multicast applications, IEEE Network, vol.11, issue.6, 1997. ,
DOI : 10.1109/65.642357
Architectural considerations for a new generation of protocols, ACM symposium on Communications architectures and protocols (SIGCOMM'90), 1990. ,
IANA Guidelines for IPv4 Multicast Address Assignments, IETF Request for Comments, RFC, vol.5771, 2010. ,
DOI : 10.17487/rfc5771
Codes AL-FEC hautes performances pour les canaux à effacements : variations autour des codes LDPC, 2010. ,
URL : https://hal.archives-ouvertes.fr/tel-00451336
Optimizing the error recovery capabilities of LDPC-staircase codes featuring a Gaussian elimination decoding scheme, 2008 10th International Workshop on Signal Processing for Space Communications, 2008. ,
DOI : 10.1109/SPSC.2008.4686723
URL : https://hal.archives-ouvertes.fr/inria-00291656
Le RFC 5170 en pratique : conception et évaluation d'un codec AL-FEC LDPC-staircase hautes performances, Colloque Francophone sur l'Ingénierie des Protocoles (CFIP), 2009. ,
Analysis of Quasi-Cyclic LDPC codes under ML decoding over the erasure channel, 2010 International Symposium On Information Theory & Its Applications, 2010. ,
DOI : 10.1109/ISITA.2010.5649581
URL : https://hal.archives-ouvertes.fr/hal-00506039
Low-rate coding using incremental redundancy for GLDPC bibliography 167 ,
DOI : 10.1109/iwssc.2008.4656817
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.139.5949
Coding Theorems for " Turbo-Like " Codes, Proceedings Thirty-Sixth Annual Allerton Conference on Communication, Control, and Computing, 1998. ,
Estimates of Error Rates for Codes on Burst-Noise Channels, Bell System Technical Journal, vol.42, issue.5, pp.1977-1997, 1963. ,
DOI : 10.1002/j.1538-7305.1963.tb00955.x
A reliable multicast framework for light-weight sessions and application level framing, IEEE/ACM Transactions on Networking, vol.5, issue.6, 1997. ,
Performance verification results for MBMS EFEC candidates r3, 2013. ,
Low-density parity-check codes, IEEE Transactions on Information Theory, vol.8, issue.1, 1960. ,
DOI : 10.1109/TIT.1962.1057683
Low-density parity-check codes, IEEE Transactions on Information Theory, vol.8, issue.1, 1962. ,
Capacity of a Burst-Noise Channel, Bell System Technical Journal, vol.39, issue.5, pp.1253-1265, 1960. ,
DOI : 10.1002/j.1538-7305.1960.tb03959.x
Image Inpainting : Overview and Recent Advances, IEEE Signal Processing Magazine, vol.31, issue.1, 2014. ,
DOI : 10.1109/MSP.2013.2273004
URL : https://hal.archives-ouvertes.fr/hal-00876076
Allocation Guidelines for IPv6 Multicast Addresses, IETF Request for Comments RFC, vol.3307, 2002. ,
DOI : 10.17487/rfc3307
FLUTE Enhancements -Design Details, 2013. ,
Hybrid reliable multicast with TCP-XM, Proceedings of the 2005 ACM conference on Emerging network experiment and technology , CoNEXT'05, 2005. ,
DOI : 10.1145/1095921.1095945
Irregular Repeat- Accumulate Codes, 2nd. Int. Conference on Turbo Codes, 2000. ,
Introducing Low-Density Parity-Check Codes, 2006. ,
Reed-Solomon Forward Error Correction (FEC) Schemes, IETF Request for Comments RFC, vol.5510, 2009. ,
DOI : 10.17487/rfc5510
Solving Large Sparse Linear Systems Over Finite Fields, Advances in Cryptology (Crypto'90), 1991. ,
DOI : 10.1007/3-540-38424-3_8
The Lightweight User Datagram Protocol (UDP-Lite), IETF Request for Comments, p.3828, 2004. ,
DOI : 10.17487/rfc3828
On generalized low-density parity-check codes based on Hamming component codes, IEEE Communications Letters, vol.3, issue.8, pp.248-250, 1999. ,
DOI : 10.1109/4234.781010
RTP Payload Format for Generic Forward Error Correction, IETF Request for Comments RFC, vol.5109, 2007. ,
DOI : 10.17487/rfc5109
Reliable Multimedia Download Delivery in Cellular Broadcast Networks, IEEE Transactions on Broadcasting, vol.53, issue.1, 2007. ,
DOI : 10.1109/TBC.2007.891703
Asynchronous Layered Coding: a Scalable Reliable Multicast Protocol, Progress, 2000. ,
Wave and Equation Based Rate Control (WE- BRC) Building Block, IETF Request for Comments, RFC, vol.3738, p.169, 2004. ,
DOI : 10.17487/rfc3738
Raptor Forward Error Correction Scheme for Object Delivery, IETF Request for Comments, RFC, vol.5053, 2007. ,
DOI : 10.17487/rfc5053
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.374.4050
RaptorQ Forward Error Correction Scheme for Object Delivery, IETF Request for Comments, RFC, vol.6330, 2011. ,
DOI : 10.17487/rfc6330
Universal Object Delivery using RaptorQ, IETF RMT Working Group, Work in Progress, p.0, 2011. ,
Layered Coding Transport (LCT) Building Block, IETF Request for Comments, RFC, vol.5651, 2009. ,
DOI : 10.17487/rfc5651
Asynchronous Layered Coding (ALC) Protocol Instantiation, IETF Request for Comments, RFC, vol.5775, 2010. ,
DOI : 10.17487/rfc5775
Contrôle de congestion équitable pour le multicast et interface avec le niveau applicatif, 2010. ,
Information Theory, Inference and Learning Algorithms, p.521642981, 2003. ,
Performance analysis of a high-performance real-time application with several AL-FEC schemes, IEEE Local Computer Network Conference, 2010. ,
DOI : 10.1109/LCN.2010.5735700
URL : https://hal.archives-ouvertes.fr/inria-00506065
Complexity comparison of the use of Vandermonde versus Hankel matrices to build systematic MDS Reed-Solomon codes, 2012 IEEE 13th International Workshop on Signal Processing Advances in Wireless Communications (SPAWC), 2012. ,
DOI : 10.1109/SPAWC.2012.6292924
URL : https://hal.archives-ouvertes.fr/hal-00719314
Design of small rate, close to ideal, GLDPC-staircase AL-FEC codes for the erasure channel, 2012 IEEE Global Communications Conference (GLOBECOM), 2012. ,
DOI : 10.1109/GLOCOM.2012.6503433
URL : https://hal.archives-ouvertes.fr/hal-00736071
Impacts of the Packet Scheduling on the Performance of Certain Erasure Codes: Methodology and Application to GLDPC-Staircase, 2013. ,
Optimization with exit functions of GLDPC-Staircase codes for the BEC, 2012 IEEE 13th International Workshop on Signal Processing Advances in Wireless Communications (SPAWC), 2012. ,
DOI : 10.1109/SPAWC.2012.6292979
URL : https://hal.archives-ouvertes.fr/hal-00719321
Good coupling between LDPC-staircase and Reed-Solomon for the design of GLDPC codes for the erasure channel, 2013 IEEE Wireless Communications and Networking Conference (WCNC), 2013. ,
DOI : 10.1109/WCNC.2013.6554790
URL : https://hal.archives-ouvertes.fr/hal-00781921
IPTV: An End to End Perspective, Journal of Communications, vol.5, issue.5, 2010. ,
Community Viewing meets Network Coding: New Strategies for Distribution, Consumption and Protection of TV Content, 2011. ,
Impacts of packet scheduling and packet loss distribution on FEC Performances, Proceedings of the 2005 ACM conference on Emerging network experiment and technology , CoNEXT'05, 2005. ,
DOI : 10.1145/1095921.1095944
URL : https://hal.archives-ouvertes.fr/inria-00000146
Large scale content distribution protocols, ACM SIGCOMM Computer Communication Review, vol.35, issue.3, 2005. ,
DOI : 10.1145/1096536.1096550
URL : https://hal.archives-ouvertes.fr/inria-00001240
Parity-based loss recovery for reliable multicast transmission, IEEE/ACM Transactions on Networking, vol.6, issue.4, 1998. ,
DOI : 10.1145/263109.263181
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.126.5885
FLUTE -File Delivery over Unidirectional Transport, IETF RMT Working Group, 2004. ,
DOI : 10.17487/rfc6726
URL : https://hal.archives-ouvertes.fr/hal-00749951
FLUTE -File Delivery over Unidirectional Transport, IETF Request for Comments, p.6726, 2012. ,
Reliable multicast transport protocol rmtp, IEEE Journal on Selected Areas in Communications, vol.15, issue.3, 1997. ,
Options for Repair of Streaming Media, IETF Request for Comments, 1998. ,
DOI : 10.17487/rfc2354
A tutorial on Reed-Solomon coding for faulttolerance in RAID-like systems, 1996. ,
Reduction of Huge, Sparse Matrices over Finite Fields Via Created Catastrophes, Experimental Mathematics, vol.32, issue.2, 1992. ,
DOI : 10.1080/10586458.1992.10504250
On the Use of On-Demand Layer Addition (ODL) with Multi-Layer Multicast Transmission Techniques, 2nd Workshop on Networked Group Communication (NGC2000), 2000. ,
Simple Authentication Schemes for the Asynchronous Layered Coding (ALC) and NACK-Oriented Reliable Multicast (NORM) Protocols, IETF Request for Comments, RFC, vol.6584, 2012. ,
DOI : 10.17487/rfc6584
URL : https://hal.archives-ouvertes.fr/hal-00745908
FCAST: Object Delivery for the Asynchronous Layered Coding (ALC) and NACK-Oriented Reliable Multicast (NORM) Protocols, IETF RMT Working Group, IETF Request for Comments, 2013. ,
DOI : 10.17487/rfc6968
URL : https://hal.archives-ouvertes.fr/hal-00844825
LDPC-Staircase Forward Error Correction (FEC) Scheme for FECFRAME, IETF FECFRAME Working Group, IETF Request for Comments, p.6816, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00781906
Simple Reed-Solomon Forward Error Correction (FEC) Scheme for FECFRAME, IETF FECFRAME Working Group, IETF Request for Comments, p.6865, 2013. ,
DOI : 10.17487/rfc6865
URL : https://hal.archives-ouvertes.fr/hal-00799727
RS + LDPC-Staircase codes for the erasure channel: Standards, usage and performance, 2013 IEEE 9th International Conference on Wireless and Mobile Computing, Networking and Communications (WiMob), 2013. ,
DOI : 10.1109/WiMOB.2013.6673424
TESLA source authentication in the ALC and NORM protocols, IETF Request for Comments, p.5776, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00000161
Design of a multicast file transfer tool on top of ALC, Proceedings ISCC 2002 Seventh International Symposium on Computers and Communications, 2002. ,
DOI : 10.1109/ISCC.2002.1021787
Low Density Parity Check (LDPC) Staircase and Triangle Forward Error Correction (FEC) Schemes, IETF Request for Comments, RFC, vol.5170, 2008. ,
DOI : 10.17487/rfc5170
URL : https://hal.archives-ouvertes.fr/inria-00000147
The Generalized Object Encoding (GOE) Approach for the Forward Erasure Correction (FEC) Protection of Objects and its Application to Reed-Solomon Codes over GF(2x) Work in Progress: <draft-roca-rmt-goe-fec-01, IETF RMT Working Group, 2012. ,
The Generalized Object Encoding (GOE) LDPC-Staircase FEC Scheme IETF RMT Working Group, Work in Progress: <draft-roca-rmt-goe-ldpc- 01, 2012. ,
On generator matrices of MDS codes, IEEE Transactions on Information Theory, issue.6, p.31, 1985. ,
Memory consumption analysis for the GOE and PET Unequal Erasure Protection schemes, 2012 IEEE International Conference on Communications (ICC), 2012. ,
DOI : 10.1109/ICC.2012.6363964
URL : https://hal.archives-ouvertes.fr/hal-00668826
Unequal erasure protection and object bundle protection with the generalized object encoding approach, 2011. ,
URL : https://hal.archives-ouvertes.fr/inria-00612583
MAP decoding for LDPC codes over the binary erasure channel, 2011 IEEE Information Theory Workshop, 2011. ,
DOI : 10.1109/ITW.2011.6089364
Definition of a general and intuitive loss model for packet networks and its implementation in the Netem module in the Linux kernel, 2012. ,
LDPC Codes: An Introduction, 2003. ,
DOI : 10.1007/978-3-0348-7865-4_5
Raptor codes. Foundations and Trends in Communications and Information Theory, pp.213-322, 2011. ,
DOI : 10.1109/tit.2006.874390
Erasure Codes with a Banded Structure for Hybrid Iterative-ML Decoding, GLOBECOM 2009, 2009 IEEE Global Telecommunications Conference, 2009. ,
DOI : 10.1109/GLOCOM.2009.5426098
URL : https://hal.archives-ouvertes.fr/hal-00788318
Supercharged Codes, Progress: <draft-stauffer-rmt- bb-fec-supercharged-03>, 2013. ,
Dynamic Adaptive Streaming over HTTP ? Design Principles and Standards, 2011. ,
Windowed Erasure Codes, 2006 IEEE International Symposium on Information Theory, pp.509-513, 2006. ,
DOI : 10.1109/ISIT.2006.261768
Random Matrices and Codes for the Erasure Channel, Algorithmica, vol.52, issue.2, 2008. ,
DOI : 10.1007/s00453-008-9192-0
A recursive approach to low complexity codes, IEEE Transactions on Information Theory, vol.27, issue.5, pp.533-547, 1981. ,
DOI : 10.1109/TIT.1981.1056404
On quasi-cyclic repeat-accumulate codes, Proc. 37th Allerton Conf. Communication, Control and Computing, pp.249-259, 1999. ,
Code Poetry and Text Adventures, 2013. ,
On-the-Fly Erasure Coding for Real-Time Video Applications, IEEE Transactions on Multimedia, vol.13, issue.4, 2011. ,
DOI : 10.1109/TMM.2011.2126564
Videoconferencing on the Internet, IEEE/ACM Transactions on Networking, vol.4, issue.3, 1996. ,
DOI : 10.1109/90.502233
Packetizing for the Erasure Broadcast Channel with an Internet Application, International Conf. on Combinatorics, Information Theory and Statistics, 1997. ,
Forward Error Correction (FEC) Framework, IETF Request for Comments, RFC, vol.6363, 2011. ,
DOI : 10.17487/rfc6363
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.228.3307
Forward Error Correction (FEC) Building Block, IETF Request for Comments, RFC, vol.5052, 2007. ,
DOI : 10.17487/rfc5052
Random Binary FEC Scheme for Bundle Protocol IETF Network Working Group, Work in Progress: <draft-irtf-dtnrg-zinky-random-binary-fec- scheme-00>, 2012. ,
On two probabilistic decoding algorithms for binary linear codes, IEEE Transactions on Information Theory, vol.37, issue.6, pp.17707-1716, 1991. ,
DOI : 10.1109/18.104339
Decoding complexity of lowdensity codes for transmission in a channel with erasures, Probl. Peredachi Inf, vol.48, pp.18-28, 1974. ,
