A Letter of Mr. Isaac Newton, Professor of the Mathematicks in the University of Cambridge; Containing His New Theory about Light and Colors: Sent by the Author to the Publisher from Cambridge, Febr. 6. 1671/72; In Order to be Communicated to the R. Society, Philosophical Transactions of the Royal Society of London, vol.6, issue.69-80, pp.1665-16783075, 1965. ,
DOI : 10.1098/rstl.1671.0072
Particle???wave association on a fluid interface, Journal of Fluid Mechanics, vol.554, issue.-1, pp.85-108, 2006. ,
DOI : 10.1017/S0022112006009190
Dynamical phenomena: Walking and orbiting droplets, Nature, vol.9, issue.7056, pp.208-208, 2005. ,
DOI : 10.1103/PhysRevLett.82.3847
A lorentzcovariant connection for canonical gravity, SIGMA, vol.7, issue.083, p.10, 2011. ,
Black hole lasers, a mode analysis, Physical Review D, vol.81, issue.8, p.84042, 2010. ,
DOI : 10.1103/PhysRevD.81.084042
URL : https://hal.archives-ouvertes.fr/hal-00456022
Bounding bubbles: The vertex representation of 3d group field theory and the suppression of pseudomanifolds, Physical Review D, vol.85, issue.4, p.44004, 2012. ,
DOI : 10.1103/PhysRevD.85.044004
URL : https://hal.archives-ouvertes.fr/hal-01116619
The Ball : Discovering the Object of the Game, 2012. ,
Guinness book of world records, 2010. ,
Recherches expérimentales sur la résistance de l'air exécutées à la tour Eiffel. L. Maretheux, 1907. ,
Nouvelles recherches sur la résistance de l'air et l'aviation faites au laboratoire d'Auteuil. Dunod & Pinat, 1914. ,
Experimental Investigation of the Wake behind a Sphere at Low Reynolds Numbers, Journal of the Physical Society of Japan, vol.11, issue.10, pp.1104-1108, 1956. ,
DOI : 10.1143/JPSJ.11.1104
Sur la résistance des sphéres dans l ?air en mouvement, Comptes Rendues, vol.155, pp.1597-1599, 1912. ,
Experiments on the flow past spheres at very high Reynolds numbers, Journal of Fluid Mechanics, vol.5, issue.03, pp.565-575, 1972. ,
DOI : 10.1007/BF00750790
Unsteady force measurements in sphere flow from subcritical to supercritical Reynolds numbers, Experiments in Fluids, vol.18, issue.03, pp.1439-1453, 2011. ,
DOI : 10.1007/s00348-011-1161-8
Hydrodynamique physique, EDP sciences, 2001. ,
Essai d'une nouvelle théorie de la résistance des fluides. David l'aîné, 1752. [17] RH Magarvey and Roy L Bishop. Transition ranges for three-dimensional wakes, Canadian Journal of Physics, issue.10, pp.391418-1422, 1961. ,
A Study on Vortex Shedding From Spheres in a Uniform Flow, Journal of Fluids Engineering, vol.112, issue.4, pp.386-392, 1990. ,
DOI : 10.1115/1.2909415
The structure of the near wake of a sphere moving horizontally in a stratified fluid, Journal of Fluid Mechanics, vol.29, issue.-1, pp.1-21, 1993. ,
DOI : 10.1007/BF00914727
Observations of the frequencies in a sphere wake and of drag increase by acoustic excitation, Physics of Fluids, vol.31, issue.11, p.3260, 1988. ,
DOI : 10.1063/1.866937
Visual observations of the flow past a sphere at Reynolds numbers between 10 4 and 10 6, Journal of Fluid Mechanics, vol.39, issue.01, pp.187-192, 1978. ,
DOI : 10.1063/1.861854
On the Swing of a Cricket Ball in Flight, Proceedings of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.379, issue.1776, pp.109-131, 1776. ,
DOI : 10.1098/rspa.1982.0008
Effect of spin and speed on the lateral deflection (curve) of a baseball ; and the magnus effect for smooth spheres, Am. J. Phys, issue.8, pp.27589-596, 1959. ,
See the wind blow, 1971. ,
Aerodynamics of sports balls, Annual Review of Fluid Mechanics, vol.17, issue.1, pp.151-189, 1985. ,
The effects of surface roughness and tunnel blockage on the flow past spheres, Journal of Fluid Mechanics, vol.46, issue.01, pp.113-125, 1974. ,
DOI : 10.1017/S0022112074001285
Vortex shedding from spheres, Journal of Fluid Mechanics, vol.43, issue.02, pp.209-221, 1974. ,
DOI : 10.1063/1.1706409
Measurements of drag coefficients, 1962. ,
Study of sphere motion and balloon wind sensors. George C. Marshall Space Flight Center, National Aeronautics and Space Administration, 1964. ,
Aerodynamic lift and moment fluctuations of a sphere, Journal of Fluid Mechanics, vol.32, issue.03, pp.417-432, 1969. ,
DOI : 10.1017/S002211206900173X
UNSTEADY LIFT FORCE ON A TOWED SPHERE, Journal of Fluids and Structures, vol.12, issue.8, pp.949-958, 1998. ,
DOI : 10.1006/jfls.1998.0177
Numerical investigations of flow over a sphere in the subcritical and supercritical regimes, Physics of Fluids, vol.16, issue.5, p.1449, 2004. ,
DOI : 10.1063/1.1688325
Vortical structures behind a sphere at subcritical Reynolds numbers, Physics of Fluids, vol.18, issue.1, p.15102, 2006. ,
DOI : 10.1063/1.2166454
Aerodynamics of a spinning sphere, pp.777-798, 1928. ,
The Magnus or Robins effect on rotating spheres, Journal of Fluid Mechanics, vol.20, issue.03, pp.437-447, 1971. ,
DOI : 10.1063/1.1698540
The effect of spin on the flight of a baseball, American Journal of Physics, vol.76, p.119, 2008. ,
The spinning ball spiral, New Journal of Physics, vol.12, issue.9, p.93004, 2010. ,
DOI : 10.1088/1367-2630/12/9/093004
URL : https://hal.archives-ouvertes.fr/hal-01021119
Soccer ball lift coefficients via trajectory analysis, European Journal of Physics, vol.31, issue.4, p.775, 2010. ,
DOI : 10.1088/0143-0807/31/4/007
The roberto carlos spiral, APS Division of Fluid Dynamics Meeting Abstracts, 2009. ,
Traité de balistique extérieure, 1904. ,
Dialogues Concerning Two New Sciences, American Journal of Physics, vol.34, issue.3, 1914. ,
DOI : 10.1119/1.1972915
URL : https://dspace-prod.mse.jhu.edu/bitstream/1774.2/34248/355/31151030237774.pdf
The velocity dependence of aerodynamic drag : A primer for mathematicians. The American mathematical monthly, pp.127-135, 1999. ,
The motion of a heavy particle in a medium with quadratic drag force, International Journal of Nonlinear Sciences and Numerical Simulation, vol.3, issue.2, pp.121-130, 2002. ,
Approximate trajectories for projectile motion with air resistance, American Journal of Physics, vol.66, p.34, 1998. ,
The fly ball trajectory: An older approach revisited, American Journal of Physics, vol.55, issue.1, pp.37-40, 1987. ,
DOI : 10.1119/1.14968
The mathematics of projectiles in sport, 1990. ,
An optimal angle of launching a point mass in a medium with quadratic drag force. arXiv preprint physics/0506201, 2005. ,
On the optimal angle of projection in general media, American Journal of Physics, vol.65, issue.8, p.797, 1997. ,
DOI : 10.1119/1.18637
Traité de balistique expérimentale, 1884. ,
Sphere Drag Coefficients for a Broad Range of Mach and Reynolds Numbers, AIAA Journal, vol.10, issue.11, pp.1436-1440, 1972. ,
DOI : 10.2514/3.50387
A study of baseball and softball aerodynamics, Procedia Engineering, vol.34, pp.86-91, 2012. ,
DOI : 10.1016/j.proeng.2012.04.016
The science of soccer, 2002. ,
The aerodynamics of a tennis ball, Sports Engineering, vol.4, issue.4, pp.177-189, 2001. ,
DOI : 10.1046/j.1460-2687.2001.00083.x
Aerodynamics of contemporary FIFA soccer balls, Procedia Engineering, vol.13, pp.188-193, 2011. ,
DOI : 10.1016/j.proeng.2011.05.071
Trajectory analysis of a soccer ball, American Journal of Physics, vol.77, issue.11, p.1020, 2009. ,
DOI : 10.1119/1.3197187
Parameter space for successful soccer kicks, European journal of physics, vol.27, issue.4, p.865, 2006. ,
Computer simulation of shuttlecock trajectories, Sports Engineering, vol.5, issue.2, pp.93-105, 2002. ,
DOI : 10.1046/j.1460-2687.2002.00100.x
Aerodynamic properties of badminton shuttlecock, International Journal of Mechanical and Materials EngineeringIJMME), vol.4, issue.3, pp.266-272, 2009. ,
Measurements of aerodynamic properties of badminton shuttlecocks, Procedia Engineering, vol.2, issue.2, pp.2487-2492, 2010. ,
DOI : 10.1016/j.proeng.2010.04.020
Aerodynamics of badminton shuttlecocks, Journal of Fluids and Structures, vol.41, 2013. ,
DOI : 10.1016/j.jfluidstructs.2013.01.009
A study of shuttlecock's trajectory in badminton, Journal of Sports Science and Medicine, vol.8, issue.4, pp.657-662, 2009. ,
Badminton shuttlecock aerodynamics : synthesizing experiment and theory, Sports Engineering, vol.15, issue.2, pp.61-71, 2012. ,
Wake-Induced Oscillatory Paths of Bodies Freely Rising or Falling in Fluids, Annual Review of Fluid Mechanics, vol.44, issue.1, pp.97-121, 2012. ,
DOI : 10.1146/annurev-fluid-120710-101250
Wind dispersal of artifical fruits varying in mass, area, and morphology, Ecology, pp.27-42, 1987. ,
WIND-BORNE SEED AND FRUIT MOVEMENT, New Phytologist, vol.72, issue.2, pp.405-418, 1975. ,
DOI : 10.1111/j.1469-8137.1975.tb01404.x
Flutter and tumble in fluids, Physics World, vol.12, issue.4, pp.21-25, 1999. ,
DOI : 10.1088/2058-7058/12/4/21
From Flutter to Tumble: Inertial Drag and Froude Similarity in Falling Paper, Physical Review Letters, vol.81, issue.2, pp.345-348, 1998. ,
DOI : 10.1103/PhysRevLett.81.345
Thomas William Coke Earl of Leicester, and Musée Jacquemart-André. Le Codex Hammer de Leonard de Vinci : les eaux, la terre, l'univers :[exposition] Musée Jacquemart-André, 1982. ,
Bubbles, Physics of Fluids, vol.16, issue.6, p.1852, 2004. ,
DOI : 10.1063/1.1695308
URL : https://hal.archives-ouvertes.fr/hal-01441566
On the rise of small air bubbles in water, Journal of Fluid Mechanics, vol.28, issue.03, pp.249-275, 1956. ,
DOI : 10.1017/S0022112056000159
Path instability of a rising bubble. Physical review letters, p.14502, 2001. ,
Force measurements on rising bubbles, Journal of Fluid Mechanics, vol.569, issue.1, pp.51-60, 2006. ,
Dynamical model of bubble path instability . Physical review letters, p.144508, 2006. ,
Nonvertical ascension or fall of a free sphere in a Newtonian fluid, Physics of Fluids, vol.15, issue.1, p.9, 2003. ,
DOI : 10.1063/1.1529179
URL : https://hal.archives-ouvertes.fr/hal-01447015
Instabilities and transition of a sphere falling or ascending freely in a Newtonian fluid, Journal of Fluid Mechanics, vol.508, issue.1, pp.201-239, 2004. ,
DOI : 10.1017/S0022112004009164
URL : https://hal.archives-ouvertes.fr/hal-01447013
The effect of Reynolds number on the dynamics and wakes of freely rising and falling spheres, Journal of Fluid Mechanics, vol.32, p.251, 2010. ,
DOI : 10.1002/(SICI)1097-0363(19990815)30:7<921::AID-FLD875>3.0.CO;2-3
Critical mass and a new periodic four-ring vortex wake mode for freely rising and falling spheres, Physics of Fluids, vol.20, issue.10, p.101701, 2008. ,
DOI : 10.1063/1.2992126
Study of sphere motion and balloon wind sensors(motion and net drag coefficients of free moving spheres-balloon wind sensors), 1964. ,
The motion of ascending and descending spheres, 1965. ,
Dye Visualization - A Method for Investigating Biomechanical Flows, Current Pharmaceutical Biotechnology, vol.13, issue.11, pp.2141-2152, 2012. ,
DOI : 10.2174/138920112802502042
URL : https://hal.archives-ouvertes.fr/hal-00784010
Démonstration physique du mouvement de rotation de la ,
Dialogue Concerning the Two Chief World Systems : Ptolemaic & Copernican, 1967. ,
Les preuves mécaniques de la rotation de la terre. Gauthier-Villars, Imprimeur-Libraire, 1883. ,
Versuche über das Gesetz des Falls, über den Widerstand der Luft und über di Umdrehung der Erde, 1804. ,
Fallversuche über die Umdrehung der Erde, JG Engelhardt, p.1832 ,
DOI : 10.1002/andp.18331051209
La rotation de la terre, ses preuves mécaniques anciennes et nouvelles, 1911. ,
Petite histoire de la force de Coriolis, Reflets de la physique, issue.17, pp.18-21, 2009. ,
DOI : 10.1051/refdp/2009026
URL : https://hal.archives-ouvertes.fr/hal-00490053
Experiments on the deviations of falling bodies, Proceedings of the American Academy of Arts and Sciences, pp.339-349, 1904. ,
Air resistance to falling inch spheres, Proceedings of the American Academy of Arts and Sciences, pp.379-384, 1910. ,
Mémoire sur les équations du mouvement relatif des systèmes de corps, p.1835 ,
Unsteady aerodynamic force on a knuckleball in soccer, Procedia Engineering, vol.2, issue.2, pp.2455-2460, 2010. ,
DOI : 10.1016/j.proeng.2010.04.015
Sports ball aerodynamics: A numerical study of the erratic motion of soccer balls, Computers & Fluids, vol.38, issue.6, pp.1091-1100, 2009. ,
DOI : 10.1016/j.compfluid.2008.11.001
Wind tunnel measurement and flow visualisation of soccer ball knuckle effect, Sports Engineering, vol.62, issue.1, pp.29-40, 2012. ,
DOI : 10.1007/s12283-012-0085-8
Flow structure of knuckling effect in footballs, Journal of Fluids and Structures, vol.27, issue.5-6, pp.727-733, 2011. ,
DOI : 10.1016/j.jfluidstructs.2011.03.016
ENGINEERING OF SPORT MEETING: In Volleyball, Crafty Players Serve Up an Aerodynamic Crisis, Science, vol.306, issue.5693, p.30642, 2004. ,
DOI : 10.1126/science.306.5693.42a
Analysis of knuckleball trajectories, Procedia Engineering, vol.34, pp.116-121, 2012. ,
The aerodynamics of the knuckleball pitch : An experimental investigation into the effects that the seam and slow rotation have on a baseball, 2009. ,
Ball impact dynamics of knuckling shot in soccer, Procedia Engineering, vol.34, pp.200-205, 2012. ,
DOI : 10.1016/j.proeng.2012.04.035
The strange flight behaviour of slowly spinning soccer balls, Scientific Reports, vol.05, issue.3, 2013. ,
DOI : 10.1038/srep01871
Histoire du badminton, 2002. ,
Shuttlecock aerodynamics, Sports Engineering, vol.2, issue.2, pp.85-96, 1999. ,
Rigid-body dynamics of a football, Am. J. Phys, vol.55, issue.5, p.5, 1987. ,
On the flight of an american football. arXiv preprint, 2007. ,
Aerodynamics of an Australian Rules Foot Ball and Rugby Ball, Computational Fluid Dynamics for Sport Simulation, pp.103-127, 2009. ,
DOI : 10.1007/978-3-642-04466-3_5
The importance of being light: aerodynamic forces and weight in ski jumping, Journal of Biomechanics, vol.35, issue.8, pp.1059-1069, 2002. ,
DOI : 10.1016/S0021-9290(02)00066-0
Aerodynamics of ski jumping: experiments and CFD simulations, Experiments in Fluids, vol.38, issue.8, pp.949-964, 2006. ,
DOI : 10.1007/s00348-006-0213-y
Simulation of javelin flight using experimental aerodynamic data, Journal of Biomechanics, vol.17, issue.10, pp.769-776, 1984. ,
DOI : 10.1016/0021-9290(84)90107-6
Optimal javelin trajectories, Journal of Biomechanics, vol.17, issue.10, pp.777-787, 1984. ,
DOI : 10.1016/0021-9290(84)90108-8
Simulation of frisbee flight, Proceedings of the 5 th Conference on Mathematics and Computers in Sport, 2000. ,
The physics of frisbees, 2005. ,
Flight and attitude dynamics measurements of an instrumented frisbee, Measurement Science and Technology, vol.16, issue.3, p.738, 2005. ,
De aquae communis nonnullis qualitatibus tractatus. [Typis Joan, p.1756 ,
The leidenfrost phenomenon: film boiling of liquid droplets on a flat plate, International Journal of Heat and Mass Transfer, vol.9, issue.11, pp.1167-1188, 1966. ,
DOI : 10.1016/0017-9310(66)90112-8
Trapping Leidenfrost Drops with Crenelations, Physical Review Letters, vol.107, issue.11, p.114503, 2011. ,
DOI : 10.1103/PhysRevLett.107.114503
URL : https://hal.archives-ouvertes.fr/hal-00998002
A ratchet trap for leidenfrost drops, Journal of Fluid Mechanics, vol.696, pp.215-227, 2012. ,
Leidenfrost on a ratchet, Nature Physics, vol.21, issue.5, pp.395-398, 2011. ,
DOI : 10.1038/nphys1925
URL : https://hal.archives-ouvertes.fr/hal-00997984
Leidenfrost Gas Ratchets Driven by Thermal Creep, Physical Review Letters, vol.107, issue.16, p.164502, 2011. ,
DOI : 10.1103/PhysRevLett.107.164502
Effect of an electric field on a Leidenfrost droplet, Soft Matter, vol.17, issue.28, pp.5992-5995, 2012. ,
DOI : 10.1039/c2sm25656h
URL : https://hal.archives-ouvertes.fr/hal-00698584
Collected papers of Sir James Dewar, 1927. ,
Magnetic control of Leidenfrost drops, Physical Review E, vol.85, issue.5, p.56311, 2012. ,
DOI : 10.1103/PhysRevE.85.056311
URL : https://hal.archives-ouvertes.fr/hal-00996514
Shapes of rolling liquid drops, Journal of Fluid Mechanics, vol.512, issue.1, pp.133-151, 2004. ,
DOI : 10.1017/S0022112004009747
Singular jets and bubbles in drop impact. Physical review letters, p.124501, 2006. ,
Generation and stability of toroidal droplets in a viscous liquid. Physical review letters, p.234501, 2009. ,
The shrinking instability of toroidal liquid droplets in the Stokes flow regime, The European Physical Journal E, vol.85, issue.3, pp.1-6, 2011. ,
DOI : 10.1140/epje/i2011-11032-9
The interpretation of band spectra, p.235, 1975. ,
CRC handbook of chemistry and physics, 2012. ,
Calculation of the surface tension of oxygen using moleculardynamics simulations, The Journal of chemical physics, vol.124, p.14709, 2006. ,
Measurements of the Surface Tension of Liquid Oxygen in High Magnetic Fields, Journal of the Physical Society of Japan, vol.61, issue.10, pp.613631-3635, 1992. ,
DOI : 10.1143/JPSJ.61.3631
Leidenfrost drops, Physics of Fluids, vol.15, issue.6, pp.1632-1637, 2003. ,
DOI : 10.1063/1.1572161
URL : https://hal.archives-ouvertes.fr/hal-00014747
Motion and shape of a viscoelastic drop falling through a viscous fluid, Journal of Fluid Mechanics, vol.497, pp.235-252, 2003. ,
Bubble dynamics and cavitation, Annual Review of Fluid Mechanics, vol.9, issue.1, pp.145-185, 1977. ,
Analysis of Rayleigh???Plesset dynamics for sonoluminescing bubbles, Journal of Fluid Mechanics, vol.365, pp.171-204, 1998. ,
DOI : 10.1017/S0022112098001207
Dynamics of transient cavities, Journal of Fluid Mechanics, vol.XXXIV, issue.1, pp.1-19, 2007. ,
DOI : 10.1103/PhysRevLett.93.198003
URL : https://hal.archives-ouvertes.fr/hal-00453628
Controlled impact of a disk on a water surface : cavity dynamics Approach to universality in axisymmetric bubble pinch-off, 140] Stephan Gekle, Jacco H Snoeijer, Detlef Lohse, and Devaraj van der Meer, p.381036305, 2009. ,
Dynamics of inviscid capillary breakup: collapse and pinchoff of a film bridge, Journal of Fluid Mechanics, vol.341, issue.1, pp.245-267, 1997. ,
DOI : 10.1017/S002211209700548X
Self-similar capillary pinchoff of an inviscid fluid. Physical review letters, pp.704-707, 1998. ,
Capillary pinch-off in inviscid fluids, Physics of Fluids, vol.15, issue.2, p.568, 2003. ,
DOI : 10.1063/1.1537237
On the stability of the motion of Saturn's Rings, 1959. ,
DOI : 10.1017/CBO9780511698095.022
The instability of an annular thread of fluid, J. Fluid Mech, vol.12, issue.2, p.309, 1962. ,
Capillary breakup of a liquid torus, Journal of Fluid Mechanics, vol.593, pp.281-292, 2013. ,
DOI : 10.1093/qjmam/55.3.327
Vibrations of a diamagnetically levitated water droplet, Physical Review E, vol.81, issue.5, p.56312, 2010. ,
DOI : 10.1103/PhysRevE.81.056312
Magnetic Levitation of liquid helium, Journal of Low Temperature Physics, vol.6, issue.196, pp.101-131, 1997. ,
DOI : 10.1007/BF02403919
Magnetic levitation of large water droplets and mice, Advances in Space Research, vol.45, issue.1, pp.208-213, 2010. ,
DOI : 10.1016/j.asr.2009.08.033
Optimal velocity in a race, The American Mathematical Monthly, vol.81, issue.5, pp.474-480, 1974. ,
Optimal patterns of glider dynamic soaring. Optimal control applications and methods, pp.67-89, 2004. ,
Surface Tension Transport of Prey by Feeding Shorebirds: The Capillary Ratchet, Science, vol.320, issue.5878, pp.931-934, 2008. ,
DOI : 10.1126/science.1156023
Aerodynamics of a knuckleball, American Journal of Physics, vol.43, p.960, 1975. ,
Computational modelling of manually stitched soccer balls, Proceedings of the Institution of Mechanical Engineers, Part L : Journal of Materials Design and Applications, pp.259-268, 2006. ,
DOI : 10.1243/14644207JMDA83
