150 10.8 Propagating the expected type, p.151 ,
25 3.2 Implementation of write-once references, p.26 ,
29 3.6 Fixing the racy program, using a lock, 30 3.7 Hiding internal state via a lock, p.30 ,
49 4.2 A union-find data structure implemented with nesting (interface) 51 4.3 A union-find data structure implemented with nesting, p.52 ,
57 4.7 A program involving conjunction rejected by the type-checker, p.58 ,
60 4.10 Specialized implementation of a channel (interface) Implementation of a server using mychannel, p.62 ,
166 11.7 A complete subtraction example (kinds omitted for readability) 168 11.8 A valid Mezzo program that can't be type-checked 172 11.9 The interface of the Derivations module 173 12.1 First merge example 176 12.2 Second merge example, 176 12.5 Computing the ? function ,
Checking and inferring local non-aliasing, ACM SIGPLAN Notices, vol.38, issue.5, pp.129-140, 2003. ,
L 3 : A linear language with locations, Fundamenta Informaticae, vol.77, issue.4, pp.397-449, 2007. ,
Resource-based programming in Plaid. Fun Ideas and Thoughts, 2010. ,
Modular typestate checking of aliased objects, Object- Oriented Programming, Systems, Languages, and Applications (OOPSLA), pp.301-320, 2007. ,
Unify and conquer (garbage, updating, aliasing, ...) in functional languages, ACM Symposium on Lisp and Functional Programming (LFP), pp.218-226, 1990. ,
Checking Concurrent Typestate with Access Permissions in Plural: A Retrospective, Engineering of Software, pp.35-48, 2011. ,
DOI : 10.1007/978-3-642-19823-6_4
A Decidable Fragment of Separation Logic, Foundations of Software Technology and Theoretical Computer Science (FSTTCS), pp.97-109, 2004. ,
DOI : 10.1007/978-3-540-30538-5_9
Smallfoot: Modular Automatic Assertion Checking with Separation Logic, Formal Methods for Components and Objects, pp.115-137, 2005. ,
DOI : 10.1007/11804192_6
Symbolic Execution with Separation Logic, Asian Symposium on Programming Languages and Systems (APLAS), pp.52-68, 2005. ,
DOI : 10.1007/11575467_5
A decision procedure for satisfiability in separation logic with inductive predicates, Proceedings of the Joint Meeting of the Twenty-Third EACSL Annual Conference on Computer Science Logic (CSL) and the Twenty-Ninth Annual ACM/IEEE Symposium on Logic in Computer Science (LICS), CSL-LICS '14, p.15, 2013. ,
DOI : 10.1145/2603088.2603091
Specification and verification, Communications of the ACM, vol.54, issue.6, pp.81-91, 2011. ,
DOI : 10.1145/1953122.1953145
The Spec# Programming System: An Overview, Construction and Analysis of Safe, Secure and Interoperable Smart devices (CASSIS), pp.49-69, 2004. ,
DOI : 10.1007/978-3-540-30569-9_3
Checking Interference with Fractional Permissions, Static Analysis Symposium (SAS), volume 2694 of Lecture Notes in Computer Science, pp.55-72, 2003. ,
DOI : 10.1007/3-540-44898-5_4
Semantics of fractional permissions with nesting, ACM Transactions on Programming Languages and Systems, vol.32, issue.6, 2010. ,
DOI : 10.1145/1749608.1749611
The Design and Formalization of Mezzo, a Permission-Based Programming Language, ACM Transactions on Programming Languages and Systems, vol.38, issue.4, 2014. ,
DOI : 10.1145/2837022
URL : https://hal.archives-ouvertes.fr/hal-01246534
Type Soundness and Race Freedom for Mezzo, Proceedings of the 12th International Symposium on Functional and Logic Programming, pp.253-269, 2014. ,
DOI : 10.1007/978-3-319-07151-0_16
URL : https://hal.archives-ouvertes.fr/hal-01081194
The ML kit (version 1), 1993. ,
F-bounded polymorphism for object-oriented programming, Proceedings of the fourth international conference on Functional programming languages and computer architecture, pp.273-280, 1989. ,
Compositional shape analysis by means of bi-abduction, Principles of Programming Languages (POPL), pp.289-300, 2009. ,
Characteristic Formulae for Mechanized Program Verification, 2010. ,
Tractable reasoning in a fragment of separation logic, CONCUR 2011?Concurrency Theory, pp.235-249, 2011. ,
Polymorphic subtyping without distributivity, Proceedings of the 23rd International Symposium on Mathematical Foundations of Computer Science, pp.346-355, 1998. ,
DOI : 10.1007/BFb0055784
Effective interactive proofs for higher-order imperative programs, International Conference on Functional Programming (ICFP), pp.79-90, 2009. ,
Object-oriented programming versus abstract data types, Foundations of Object- Oriented Languages, pp.151-178, 1991. ,
Ownership Types: A Survey, Aliasing in Object-Oriented Programming, pp.15-58, 2013. ,
DOI : 10.1007/978-3-642-36946-9_3
Functional translation of a calculus of capabilities, International Conference on Functional Programming (ICFP), pp.213-224, 2008. ,
Ownership types for flexible alias protection Relational inductive shape analysis, Object-Oriented Programming, Systems, Languages, and Applications (OOPSLA) Principles of Programming Languages (POPL), pp.48-64, 1998. ,
On understanding types, data abstraction, and polymorphism, ACM Computing Surveys, vol.17, issue.4, pp.471-522, 1985. ,
DOI : 10.1145/6041.6042
Typed memory management in a calculus of capabilities, Proceedings of the 26th ACM SIGPLAN-SIGACT symposium on Principles of programming languages , POPL '99, pp.262-275, 1999. ,
DOI : 10.1145/292540.292564
Computability and complexity results for a spatial assertion language for data structures Linear logic The Stanford Encyclopedia of Philosophy, In FST TCS Foundations of Software Technology and Theoretical Computer Science, pp.108-119, 2001. ,
Enforcing high-level protocols in low-level software, Programming Language Design and Implementation (PLDI), pp.59-69, 2001. ,
Typestates for Objects, European Conference on Object- Oriented Programming, pp.465-490, 2004. ,
DOI : 10.1007/978-3-540-24851-4_21
jStar: towards practical verification for Java, Object- Oriented Programming, Systems, Languages, and Applications (OOPSLA), pp.213-226, 2008. ,
Adoption and focus: practical linear types for imperative programming, Programming Language Design and Implementation (PLDI), pp.13-24, 2002. ,
Why: a multi-language multi-prover verification tool, Research Report, vol.1366, 2003. ,
Linear logic, Theoretical Computer Science, vol.50, issue.1, pp.1-102, 1987. ,
DOI : 10.1016/0304-3975(87)90045-4
URL : https://hal.archives-ouvertes.fr/inria-00075966
FX-87 reference manual, 1987. ,
Report on the FX-91 programming language, 1992. ,
Region-based memory management in Cyclone, Programming Language Design and Implementation (PLDI), pp.282-293, 2002. ,
Uniqueness and reference immutability for safe parallelism, Object-Oriented Programming, Systems, Languages , and Applications (OOPSLA), pp.21-40, 2012. ,
The ins and outs of iteration in Mezzo, 2013. ,
SeLoger: A Tool for Graph-Based Reasoning in Separation Logic, Computer Aided Verification, pp.790-795, 2013. ,
DOI : 10.1007/978-3-642-39799-8_55
Abstract Read Permissions: Fractional Permissions without the Fractions, Verification, Model Checking and Abstract Interpretation (VMCAI), pp.315-334, 2013. ,
DOI : 10.1007/978-3-642-35873-9_20
Design considerations for ML-style module systems, Advanced Topics in Types and Programming Languages, pp.293-345, 2005. ,
Techniques for model construction in separation logic, 2013. ,
Algebraic reconstruction of types and effects, Proceedings of the 18th ACM SIGPLAN-SIGACT symposium on Principles of programming languages , POPL '91, pp.303-310, 1991. ,
DOI : 10.1145/99583.99623
Viper: a verification infrastructure for permission-based reasoning, 2014. ,
Cyclone: A safe dialect of c, USENIX Annual Technical Conference, General Track, pp.275-288, 2002. ,
Structured programming with go to statements, ACM Computing Surveys (CSUR), vol.6, issue.4, pp.261-301, 1974. ,
Focusing and Polarization in Intuitionistic Logic, Computer Science Logic, pp.451-465, 2007. ,
DOI : 10.1007/978-3-540-74915-8_34
URL : https://hal.archives-ouvertes.fr/inria-00167231
PLT-redex model of rust, 2014. ,
A functional representation of data structures with a hole, Proceedings of the 25th ACM SIGPLAN-SIGACT symposium on Principles of programming languages , POPL '98, pp.75-84, 1998. ,
DOI : 10.1145/268946.268953
Extended alias type system using separating implication, Proceedings of the 7th ACM SIGPLAN workshop on Types in language design and implementation, TLDI '11, 2011. ,
DOI : 10.1145/1929553.1929559
From system F to typed assembly language, ACM Transactions on Programming Languages and Systems, vol.21, issue.3, pp.528-569, 1999. ,
A type system for borrowing permissions, Principles of Programming Languages (POPL), pp.557-570, 2012. ,
Automated Verification of Shape and Size Properties Via Separation Logic, Verification, Model Checking and Abstract Interpretation (VMCAI), pp.251-266, 2007. ,
DOI : 10.1007/978-3-540-69738-1_18
Dependently typed programming in agda, Advanced Functional Programming, pp.230-266, 2009. ,
Separation logic + superposition calculus = heap theorem prover, Programming Language Design and Implementation (PLDI), pp.556-566, 2011. ,
Real programmers don't use pascal, Datamation, vol.29, issue.7, 1983. ,
The essence of ML type inference, Advanced Topics in Types and Programming Languages, pp.389-489, 2005. ,
Separation logic modulo theories, Programming Languages and Systems, pp.90-106, 2013. ,
Three approaches to type structure, Theory and Practice of Software Development (TAPSOFT), pp.97-138, 1985. ,
Separation logic: A logic for shared mutable data structures, Logic in Computer Science (LICS), pp.55-74, 2002. ,
Abstract Domains for the Static Analysis of Programs Manipulating Complex Data Structures . Habilitation à diriger des recherches, 2011. ,
Type checking records and variants in a natural extension of ML, Proceedings of the 16th ACM SIGPLAN-SIGACT symposium on Principles of programming languages , POPL '89, pp.77-88, 1989. ,
DOI : 10.1145/75277.75284
Secure distributed programming with value-dependent types, International Conference on Functional Programming (ICFP), pp.266-278, 2011. ,
DOI : 10.1145/2034773.2034811
URL : https://hal.archives-ouvertes.fr/hal-00939188
Safe manual memory management in Cyclone, Science of Computer Programming, vol.62, issue.2, pp.122-144, 2006. ,
DOI : 10.1016/j.scico.2006.02.003
First-class state change in plaid, ACM SIGPLAN Notices, vol.46, issue.10, pp.713-732, 2011. ,
DOI : 10.1145/2076021.2048122
A toy type language: parsing and pretty-printing, 2014. ,
A toy type language: using Fix to compute variance, 2014. ,
A toy type language: variance 101, 2014. ,
Alias Types, European Symposium on Programming (ESOP), volume 1782 of Lecture Notes in Computer Science, pp.366-381, 2000. ,
DOI : 10.1007/3-540-46425-5_24
Typestate: A programming language concept for enhancing software reliability, IEEE Transactions on Software Engineering, vol.12, issue.1, pp.157-171, 1986. ,
Unifying refinement and Hoare-style reasoning in a logic for higher-order concurrency, International Conference on Functional Programming (ICFP), pp.377-390, 2013. ,
Stateful Contracts for Affine Types, European Symposium on Programming (ESOP), pp.550-569, 2010. ,
DOI : 10.1007/978-3-642-11957-6_29
Implementation of the typed call-by-value ??-calculus using a stack of regions, Proceedings of the 21st ACM SIGPLAN-SIGACT symposium on Principles of programming languages , POPL '94, pp.188-201, 1994. ,
DOI : 10.1145/174675.177855
The subtyping problem for second-order types is undecidable, Logic in Computer Science LICS'96. Proceedings., Eleventh Annual IEEE Symposium on, pp.74-85, 1996. ,
Local reasoning about while-loops. Unpublished, 2010. ,
Linear types can change the world! In, Programming Concepts and Methods, 1990. ,
List of programming languages (alphabetical), 2014, 2014. ,
Singular they, 2014. ,
Alias Types for Recursive Data Structures, Types in Compilation (TIC), volume 2071 of Lecture Notes in Computer Science, pp.177-206, 2000. ,
DOI : 10.1007/3-540-45332-6_7
