Abstract : Computing systems have become more and more distributed and heterogeneous, making their manual administration difficult and error-prone. The Autonomic Computing approach has been proposed to overcome this issue, by automating the administration of computing systems with the help of control loops called autonomic managers. Many research works have investigated the automation of the administration functions of computing systems and today many autonomic managers are available. However the existing autonomic managers are mostly specialized in the management of few administration concerns. This makes necessary the coexistence of multiple autonomic managers for achieving a global system management. The coexistence of several managers make possible to address multiple concerns, yet requires coordination mechanisms to avoid incoherent management decisions. We investigate the use of control techniques for the design of coordination controllers, for which we exercise synchronous programming that provide formal semantics, and discrete controller synthesis to automate the construction of the controller. We follow a component-based approach, and explore modular discrete control allowing to break down the combinatorial complexity inherent to the state-space exploration technique. This improves scalability of the approach and allows constructing a hierarchical control. It also allows re-using complex managers in different contexts without modifying their control specifications. We build a component-based coordination of managers, with introspection, adaptivity and reconfiguration. This thesis details our methodology and presents case-studies. We evaluate and demonstrate the benefits of our approach by coordinating autonomic managers which address the management of availability, and the management of performance and resources optimization.
Résumé : Les systèmes informatiques sont devenus de plus en plus distribués et hétérogènes, ce qui rend leur administration manuelle difficile et source d’erreurs. L’administration autonome a été proposée comme solution à ce problème. Elle consiste à automatiser l’administration des systèmes informatiques à l’aide de boucles de contrôle appelées gestionnaires autonomes. De nombreux travaux de recherche se sont intéressés à l’automatisation des fonctions d’administration de systèmes informatiques et aujourd’hui, beaucoup de gestionnaires autonomes sont disponibles. Toutefois, les gestionnaires autonomes existants sont, la plupart, spécialisés dans la gestion de quelques aspects d’administration. Cela rend nécessaire la coexistence de plusieurs gestionnaires autonomes pour atteindre une gestion globale des systèmes. La coexistence de plusieurs gestionnaires permet la gestion de plusieurs aspects, mais nécessite des mécanismes de coordination afin d’éviter des décisions incohérentes. Nous étudions l’utilisation de techniques de contrôle pour la conception de contrôleurs de coordination, nous utilisons la programmation synchrone qui fournit des méthodes formelles, et la synthèse de contrôleur discret pour automatiser la construction de contrôleur. Nous suivons une approche à base de composants, et utilisons le contrôle discret modulaire qui permet de décomposer la complexité combinatoire inhérente à la technique d’exploration d’espace d’états. Cela améliore le passage à l’échelle de notre approche et permet la construction d’un contrôle hiérarchique. Notre approche permet la réutilisation de gestionnaires complexes dans des contextes différents, sans modifier leurs spécifications de contrôle. Nous construisons une coordination de gestionnaires basée sur le modèle à composants offrant introspection, adaptabilité et reconfiguration. Cette thèse présente notre méthodologie et des études de cas. Nous évaluons et démontrons les avantages de notre approche par la coordination de gestionnaires autonomes dédiés à la gestion de la disponibilité, et à la gestion de la performance et l’optimisation de ressources.
