Strategy for test generation from UML/OCL models with a first order logic and constraints system solvers for model interpretation
Stratégies de génération de tests à partir de modèles UML/OCL interprétés en logique du premier ordre et système de contraintes
This thesis describes an automatic test generation process from models.This process uses two modelling languages, UML4MBT and OCL4MBT, created specifically for tests generation. Theses languages are derived from UML and OCL. Therefore the behaviours, the structure and the initial state of the system are described by the class diagram, the object diagram and the state-chart.To generate tests, the evolution of the model is encoded with a transition system. Consequently, to construct a test is to find transition sequences that rely the initial state of the system to the states described by the test targets.The sequence are obtained by the resolution of animation scenarios. This resolution is executed by SMT provers and CSP solvers. To create the scenario, two dedicated meta-models, UML4MBT and CSP4MBT have been established. Theses meta-models associate first order logic formulas with the test notions. 7 strategies have been developed to improve the tests generation time. A strategy is responsible for the selection and the prioritization of the scenarios. A strategy is built upon the properties of the solvers and provers and the specification of our encoding process. Moreover the process can also be paralleled to get better performance. 5 strategies employ only a prover and 2 make the prover collaborate with a solver.Finally the interest of this process has been evaluated through a list of benchmark on various cases studies.
Les travaux présentés dans cette thèse proposent une méthode de génération automatique de tests à partir de modèles.Cette méthode emploie deux langages de modélisations UML4MBT et OCL4MBT qui ont été spécifiquement dérivées d'UML et OCL pour la génération de tests. Ainsi les comportements, la structure et l'état initial du système sont décrits au travers des diagrammes de classes, d'objets et d'états-transitions.Pour générer des tests, l'évolution du modèle est représente sous la forme d'un système de transitions. Ainsi la construction de tests est équivalente à la découverte de séquences de transitions qui relient l'état initial du système à des états validant les cibles de test.Ces séquences sont obtenues par la résolution de scénarios d'animations par des prouveurs SMT et solveurs CSP. Pour créer ces scénarios, des méta-modèles UML4MBT et CSP4MBT regroupant formules logiques et notions liées aux tests ont été établies pour chacun des outils. Afin d'optimiser les temps de générations, des stratégies ont été développé pour sélectionner et hiérarchiser les scénarios à résoudre. Ces stratégies s'appuient sur la parallélisation, les propriétés des solveurs et des prouveurs et les caractéristiques de nos encodages pour optimiser les performances. 5 stratégies emploient uniquement un prouveurs et 2 stratégies reposent sur une collaboration du prouveur avec un solveur.Finalement l’intérêt de cette nouvelle méthode à été validée sur des cas d'études grâce à l'implémentation réalisée.
