Direct Manipulation for Information Visualization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2014
Manipulation Directe pour la Visualisation d’Information
There is a tremendous effort from the information visualization (Infovis) community to design novel, more efficient or more specialized desktop visualization techniques. While visual representations and interactions are combined to create these visualizations, less effort is invested in the design of new interaction techniques for Infovis. In this thesis, I focus on interaction for Infovis and explore how to improve existing visualization techniques through efficient yet simple interactions. To become more efficient, the interaction techniques should reach beyond the standard widgets and Window/Icon/Menu/Pointer (WIMP) user interfaces. In this thesis, I argue that the design of novel interactions for visualization should be based on the direct manipulation paradigm, instrumental interaction, and take inspiration from advanced interactions investigated in HCI research but not well exploited yet in Infovis. I take examples from multiple projects I have designed to illustrate how opportunistic interactions can empower visualizations and I explore design implications raised by novel interaction techniques, such as the tradeoff between cognitive congruence and versatility, the problem of engaging interaction, and the benefits of seamless, fluid interaction. Finally, I provide guidelines and perspectives, addressing the grand challenge of building or consolidating the theory of interaction for Infovis.
La communauté de la Visualisation d'Information (Infovis) accorde une importance primordiale à la conception de techniques de visualisation nouvelles, efficaces, ou spécialisées. Alors qu'une technique de visualisation est composée à la fois de techniques de représentation et de techniques d'interaction, la conception de nouvelles techniques d'interaction pour l'Infovis passe souvent au second plan. Dans cette thèse, centrée sur l'interaction en Infovis, j'explore la conception de nouvelles techniques d'interaction afin de rendre des techniques de visualisation existantes plus efficaces, plus adaptées aux tâches utilisateur, et plus engageantes. Afin que ces techniques d'interaction soient efficaces, il est nécessaire d'abandonner les outils interactifs (widgets) standards et proposer des interfaces utilisateur allant au-delà des interfaces à fenêtres, icônes, menus et pointeur connues sous le nom d'interfaces WIMP (Window/Icon/Menu/Pointer).Dans cette thèse, je soutiens que la conception de nouvelles techniques d'interaction pour la visualisation devraient être basée sur le paradigme de la manipulation directe et sur le modèle de l'interaction instrumentale, et s'inspirer de paradigmes d'interaction établis en Interaction Homme-Machine (IHM) mais trop peu connus et reconnus en Infovis. En me basant sur plusieurs projets que j'ai menés au court de ma thèse, je démontre que la conception opportuniste d'interactions nouvelles peut rendre des techniques de visualisation plus efficaces. Ces différents projets soulèvent des problèmes de conception des techniques d'interaction, tels que le compromis entre la congruence cognitive d'une technique d'interaction et sa généricité, le problème de la conception d'interactions engageant l'utilisateur, et les mérites de l'interaction fluide et ininterrompue. Enfin, je propose un ensemble de règles dérivées des différents projets de cette thèse et je soumets des perspectives de travaux futurs, afin de contribuer au grand défi d'établir une théorie de l'interaction pour l'Infovis.
VA2_PERIN_CHARLES_17112014.pdf (27.51 Mo) Télécharger le fichier
VA2_PERIN_CHARLES_17112014_Synthese_annexes.pdf (2.01 Mo) Télécharger le fichier
Format : Autre
tel-01096366 , version 1 (17-12-2014)
tel-01096366 , version 2 (20-05-2015)
  • HAL Id : tel-01096366 , version 2
Charles Perin. Direct Manipulation for Information Visualization. Human-Computer Interaction [cs.HC]. Université Paris Sud - Paris XI, 2014. English. ⟨NNT : 2014PA112299⟩. ⟨tel-01096366v2⟩
515 Consultations
1008 Téléchargements
